supradanturbo Posted March 7, 2015 Share Posted March 7, 2015 I'm having problems with my heating. The heating is cold. There is no liquid in the passenger footwell. And there is coolant going in and coming out of the matrix Any help would be appreciated Link to comment Share on other sites More sharing options...
Morzy2k5 Posted March 7, 2015 Share Posted March 7, 2015 When you turn the heater dial from hot to cold,can you here the little Motor moving the rod down in the passenger foot well?could be stuck on cold You see. Link to comment Share on other sites More sharing options...
supradanturbo Posted March 7, 2015 Author Share Posted March 7, 2015 I think I can hear it. It was hot when I drove the car. Then turned off for a couple of hours then drove home and it was cold Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2015 Share Posted March 7, 2015 Check this in passenger footwell If okay check your coolant level in the expansion tank and in the rad, when cold ! Link to comment Share on other sites More sharing options...
supradanturbo Posted March 7, 2015 Author Share Posted March 7, 2015 Everything mechanical is working fine. The out pipe from the matrix has gone cold now Link to comment Share on other sites More sharing options...
trebor69 Posted March 7, 2015 Share Posted March 7, 2015 I had problems with mine and only a flush of the system with a hosepipe cured it. Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2015 Share Posted March 7, 2015 Everything mechanical is working fine. The out pipe from the matrix has gone cold now Have you checked the coolant levels ? Link to comment Share on other sites More sharing options...
SteveC Posted March 7, 2015 Share Posted March 7, 2015 For reference, the full thread that includes the photos above is here: http://www.mkivsupra.net/vbb/showthread.php?t=49871 Link to comment Share on other sites More sharing options...
supradanturbo Posted March 15, 2015 Author Share Posted March 15, 2015 Still having problems. Everything mechanical is fine. No leaks from the matrix. Footwell etc. Just seems like an air lock. Inlet pipe is burning hot outlet is freezing cold Link to comment Share on other sites More sharing options...
