Big Mark Posted February 11, 2015 Share Posted February 11, 2015 Planning on tarting up some parts under the bonnet. I've already painted a spare set of turbo inlet pipes and the inlet manifold in High Temp Satin Black paint and will paint the existing Turbo heat shield, cam covers and throttle body when I get them off. Anyone know how easy/awkward all these parts will be to remove and refit? Any problem areas or parts that I should buy in advance? Already ordered a gasket for inlet manifold, got the large cam cover gaskets and got some spare hoses. Will get some cam cover bolt washer/gaskets. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted February 11, 2015 Share Posted February 11, 2015 I managed to take the turbo pipes off but struggled with the one at the back of the engine going into the 2nd turbo, I ended up doing it from under the car but it can be done from the top. I would replace the turbo connector pipes the ones that are prone to sag. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted February 11, 2015 Author Share Posted February 11, 2015 I've heard that back bolt can be a bit of a pain and I've already got some silicone turbo connector pipes sat on the shelf waiting to go on. Quote Link to comment Share on other sites More sharing options...
Rob W Posted February 11, 2015 Share Posted February 11, 2015 The rear turbo pipe is a pain as it's just awkward to lean over and get to it, proper kills your back. Ratchet spanners are the key! Apart from that it's an easy job. Quote Link to comment Share on other sites More sharing options...
