Josh Posted July 14, 2014 Share Posted July 14, 2014 After the exhaust hanging low and to the right (wheeey lol) for a year or so, I bought some jubilee clips to sort it out. It's gone from this To this Link to comment Share on other sites More sharing options...
Hammer Posted July 14, 2014 Share Posted July 14, 2014 Well done Josh. Bet you wish you'd of done it ages ago. Link to comment Share on other sites More sharing options...
Josh Posted July 14, 2014 Author Share Posted July 14, 2014 Well done Josh. Bet you wish you'd of done it ages ago. I do, I just kept on forgetting about it. I've put the rubber hanger back on as well, just in case the jubilee breaks There was a thread where someone else had this issue, so it may help them too Link to comment Share on other sites More sharing options...
Glanza_Mike Posted July 14, 2014 Share Posted July 14, 2014 I have this problem too mate, although mine doesn't hang low, it's just off to the right lol What exactly did u do to repair it? Link to comment Share on other sites More sharing options...
ATB Posted July 14, 2014 Share Posted July 14, 2014 Looks like a good fix! I do believe my exhaust also hangs to the right, so I might look into doing the same :-) Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 14, 2014 Share Posted July 14, 2014 Pics of your bodge then Link to comment Share on other sites More sharing options...
Josh Posted July 14, 2014 Author Share Posted July 14, 2014 I have this problem too mate, although mine doesn't hang low, it's just off to the right lol What exactly did u do to repair it? Just attached the jubilee clip around the hanger on the passenger side to pull it to the left Link to comment Share on other sites More sharing options...
mrboomberang Posted July 15, 2014 Share Posted July 15, 2014 http://img.tapatalk.com/d/14/07/15/e9u3era8.jpg Link to comment Share on other sites More sharing options...
mrboomberang Posted July 15, 2014 Share Posted July 15, 2014 Will try this Link to comment Share on other sites More sharing options...
JODY T Posted July 15, 2014 Share Posted July 15, 2014 That'll just wear through eventually leaving u with a sagging system.. Best thing to do is find one of the old mounts that held up the original mid boxes (there's one on either side) chances are they are still on the car.. Cut out the bit in the middle so u end up with a thick piece of rubber with the hole in it.. Then fit the exhaust with the original rings, then force the rubber u just cut onto the end of the back box hanger, this will position it correctly and lift it slightly Job done and it's not likly to fall off anytime.. Mines been like that for 5years... Link to comment Share on other sites More sharing options...
Glanza_Mike Posted July 15, 2014 Share Posted July 15, 2014 Jody do you have a pic of this please? I'm quite keen to get mine moved to the center in the best way possible. Link to comment Share on other sites More sharing options...
Josh Posted July 15, 2014 Author Share Posted July 15, 2014 That'll just wear through eventually leaving u with a sagging system.. Best thing to do is find one of the old mounts that held up the original mid boxes (there's one on either side) chances are they are still on the car.. Cut out the bit in the middle so u end up with a thick piece of rubber with the hole in it.. Then fit the exhaust with the original rings, then force the rubber u just cut onto the end of the back box hanger, this will position it correctly and lift it slightly Job done and it's not likly to fall off anytime.. Mines been like that for 5years... I bought a pack of two lol I've got the diamond rubber hangers (three of them), so if it sags I'll put one of those on Link to comment Share on other sites More sharing options...
JODY T Posted July 16, 2014 Share Posted July 16, 2014 I'll get a pic when it's light Link to comment Share on other sites More sharing options...
JamieP Posted July 16, 2014 Share Posted July 16, 2014 Just need to sort the rust out now:p Link to comment Share on other sites More sharing options...
JODY T Posted August 2, 2014 Share Posted August 2, 2014 Link to comment Share on other sites More sharing options...
