Elmo Posted March 21, 2014 Share Posted March 21, 2014 Hi, I’m after a little bit of help with a small l problem I have with my exhaust. I have a 3” catback exhaust (both cats are in place), however the only support for the exhaust is from the hanger on the silencer, and because of this the exhaust is able to move quite a bit, which causes the seal to go regularly where the from 1st cat joins the 2nd. What I want to do is add another support further along the exhaust to prevent excess movement/twisting. I have tried fixing a 3” exhaust clamp which will attach to a hanger but the clamp rattles on the pipe, does anyone know of something that can be used as is or modified which will support the exhaust while allowing a small amount of flexibility? Thanks. Link to comment Share on other sites More sharing options...
shaz2010 Posted March 21, 2014 Share Posted March 21, 2014 (edited) Have you got the gearbox to cat bracket fitted ? I just had to get mine on the ramps on Wednesday as I have double decat and aftermarket exhaust, it was knocking in 3 places because of the movement your on about. I had to adjust the gearbox bracket that goes onto the cat pipe which pulled it away from the underneath of the car. Also I added some extra rubbers to the midsection which prevented it moving onto my rear bumper. The bracket that is there for catching the prop shaft incase it falls was also a issue just adjusted that a little. Edited March 21, 2014 by shaz2010 (see edit history) Link to comment Share on other sites More sharing options...
Josh Posted March 21, 2014 Share Posted March 21, 2014 Can you weld a bracket on, as the Nur Spec R has a hanger that fixes in the stock position half way down the exaust on the passenger side? Link to comment Share on other sites More sharing options...
Elmo Posted March 21, 2014 Author Share Posted March 21, 2014 Have you got the gearbox to cat bracket fitted ? I just had to get mine on the ramps on Wednesday as I have double decat and aftermarket exhaust, it was knocking in 3 places because of the movement your on about. I had to adjust the gearbox bracket that goes onto the cat pipe which pulled it away from the underneath of the car. Also I added some extra rubbers to the midsection which prevented it moving onto my rear bumper. The bracket that is there for catching the prop shaft incase it falls was also a issue just adjusted that a little. No, I think the bracket has broken off at some point, there is nothing supporting the exhaust except the hanger on the silencer. The exhaust isn't knocking or anything, but overtime the movement is putting stress on the only fixed point which is the flange on the first cat, every few months it starts blowing. Link to comment Share on other sites More sharing options...
Elmo Posted March 21, 2014 Author Share Posted March 21, 2014 Can you weld a bracket on, as the Nur Spec R has a hanger that fixes in the stock position half way down the exaust on the passenger side? I know a guy who has a workshop and I occasionally use his ramp, he has welding equipment but he told me he is unable to weld to stainless, think he has the wrong type of welder. Link to comment Share on other sites More sharing options...
shaky Posted March 21, 2014 Share Posted March 21, 2014 (edited) You need a AC DC tig welder,,,there are a few places that do custom ss exhausts in Telford, give one a bell and ask them,they'll help you out, i did have the number but lost it, long life or powerflow Try this place MR TYRE Units 5&6 Sundorne Trade Park Featherbed Lane Shrewsbury United Kingdom SY1 4NS TEL: 01743 491607 Email: [email protected] VIEW MAP >> Edited March 21, 2014 by shaky (see edit history) Link to comment Share on other sites More sharing options...
Elmo Posted March 21, 2014 Author Share Posted March 21, 2014 You need a AC DC tig welder,,,there are a few places that do custom ss exhausts in Telford, give one a bell and ask them,they'll help you out, i did have the number but lost it, long life or powerflow Try this place MR TYRE Units 5&6 Sundorne Trade Park Featherbed Lane Shrewsbury United Kingdom SY1 4NS TEL: 01743 491607 Email: [email protected] VIEW MAP >> Thanks for that. There was a Powerflow Exhaust place in Telford but it recently closed down. Featherbed Lane is only 15 mins away, I'll give them a try. Cheers Link to comment Share on other sites More sharing options...
shaky Posted March 21, 2014 Share Posted March 21, 2014 (edited) The place in Shrewsbury is listed as a Powerflow dealer,,,http://www.powerflowexhausts.co.uk/dealer-locator/ Longlife...add...Oswestry Address BM Wizard Unit at the Waen Knockin Town Oswestry County Shropshire Postcode SY10 8HR CONTACT DETAILS Manager Kevin Telephone 01691 749023 Email [email protected] OPENING HOURS Mon - Fri Sat Sun Edited March 21, 2014 by shaky (see edit history) Link to comment Share on other sites More sharing options...
Elmo Posted March 21, 2014 Author Share Posted March 21, 2014 I thought all Powerflow places fabricated/assembled exhausts on site. Link to comment Share on other sites More sharing options...
shaky Posted March 21, 2014 Share Posted March 21, 2014 They make them to fit any car you have while you wait, or did?, give them a bell and ask if they can help you out with a hanger, the Telford lot did a mod on my mates ss Exhaust. It's worth a go anyway. Link to comment Share on other sites More sharing options...
Elmo Posted March 21, 2014 Author Share Posted March 21, 2014 The Telford lot did a job for me once, my tailpipe was slightly too short causing the paint to bubble on the bumper, they chopped the tail pipe off and welded in a small section of S/S to extend it slightly, problem solved but they did charge about £70 for the Privilege. Link to comment Share on other sites More sharing options...
shaz2010 Posted March 21, 2014 Share Posted March 21, 2014 No, I think the bracket has broken off at some point, there is nothing supporting the exhaust except the hanger on the silencer. The exhaust isn't knocking or anything, but overtime the movement is putting stress on the only fixed point which is the flange on the first cat, every few months it starts blowing. If It was me i would order the gearbox bracket from Toyota and get it on mate the first cat will be taking all the weight of the exhaust. Link to comment Share on other sites More sharing options...
Shane Posted March 21, 2014 Share Posted March 21, 2014 Mij exhausts in Walsall sell a selection of bolt on hangers, they have a website and an eBay shop Link to comment Share on other sites More sharing options...
