5sp to 6sp Questions
mk1its
Guys
Just a few simple questions in regards to going 6sp.
In 2013 I went the w58 5sp route and this year I'll be going either the v160 or v161 route.
With having all the tunnel and pedal work done already, is it simply a case of buying a gearbox and prop and bolting it all together? Obviously I'll need a clutch and flywheel but can I use the diff from when I was auto TT and all the clutch/brake cylinders/lines/pedals from the w58 or are they all different? :search:
Thanks in advance
Mark
I've just swapped out my A01A diff in my TT Auto for an A02B from my old V161 set up. The only difference is it goes sideways better and leaves 11's instead of 1's. :D
Interesting, so I should be ok then.... What power can the auto TT diff handle?
