mobius Posted January 21, 2014 Share Posted January 21, 2014 Getting this sometimes noise seems to be from bulkhead location, checked coolant level all OK expansion tank on limit rad down a little 5mm from bottom of cap heater works OK and more impotantly carpet at passenger footwell dry. checked when engine cold. Quote Link to comment Share on other sites More sharing options...
imi Posted January 21, 2014 Share Posted January 21, 2014 Airlock Quote Link to comment Share on other sites More sharing options...
mellonman Posted January 21, 2014 Share Posted January 21, 2014 I will bet its you heater matrix leaking, I bet over time your water level in the rad drops also, just because the xarpets dry dont mean it not the matrix Quote Link to comment Share on other sites More sharing options...
mobius Posted January 21, 2014 Author Share Posted January 21, 2014 Voice of gloom lets hope airlock will investigate further thanks Quote Link to comment Share on other sites More sharing options...
mellonman Posted January 21, 2014 Share Posted January 21, 2014 Voice of gloom lets hope airlock will investigate further thanks Sorry mate but if it happens often when you go full throttle for the first time every drive then, im pritty sure it is as I have had it happen to me for a while before it completely let go, It could be aif lockif you have changed somthing recently to do with the water system? Quote Link to comment Share on other sites More sharing options...
