Cipriani Posted January 4, 2014 Share Posted January 4, 2014 OK I have a really annoying problem! Since having my rear brakes done 2 days ago ( discs, shoes and pads) I have started getting the handbrake warning light appearing on the dash randomly while driving. The handbrake has been adjusted to 1 click which is nice but im wondering if that could be fooling something into thinking it is up slightly? Also the same day some proper clever female passenger managed to spill my cappuccino everywhere while parked up. It mostly went on the drivers carpet and seat but also went down into the gear selector area, so I quickly remover the trim and dried out as much as I could with kitchen roll. The car has since been valeted and the warming smell of freshly ground beans has vacated the cabin! So I guess the question is could the coffee have disturbed a sensor or something around the interior handbrake area? or is it more likely to be mechanically linked to the change of brakes. Link to comment Share on other sites More sharing options...
Nic Posted January 4, 2014 Share Posted January 4, 2014 (edited) Have you checked the brake fluid level? that could be the cause of the intermittent brake warning light, the sensor is very sensitive so make sure it's slightly above the max level. Edited January 4, 2014 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Cipriani Posted January 4, 2014 Author Share Posted January 4, 2014 Thank you I'll have a look just now! It's now stating on constantly also Link to comment Share on other sites More sharing options...
Cipriani Posted January 4, 2014 Author Share Posted January 4, 2014 Brake fluid is pretty much on minimum. Will get it topped up! Link to comment Share on other sites More sharing options...
Swampy442 Posted January 4, 2014 Share Posted January 4, 2014 Have you checked the brake fluid level? that could be the cause of the intermittent brake warning light, the sensor is very sensitive so make sure it's slightly above the max level. Yep, this Link to comment Share on other sites More sharing options...
