Front - End alignment
Guest Jaylovesvegas
Guest Jaylovesvegas
I need a front - end alignment the only problem is that every garage I go to in my area they say my car is way to low. I'm currently located in Brandon does anybody have a garage near my area that will do it on a low car. Thanks in advance.
Only one anywhere near to you that I'd trust is SCA in Norwich, about 40 miles from you.
You have my condolences :D
About 3 - 4 inches off the ground.
Mine was lower and had no problems getting the geo done, get a proper job done
and not just the front, the rear wheels are camber and toe adjustable as well.
