Guest jkyle69 Posted May 30, 2013 Share Posted May 30, 2013 I have removed the stock steering wheel and there is a male connector block behind so I cannot fit the boss over this as it is in the way. Can someone tell me, can you remove this connector block and is it a simple case of then connecting up the wires that feed this connector block to the new horn wires or is there other tasks that have to be done. I have definitely got the right boss from Demon Tweaks Any help appreciated! Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted May 30, 2013 Share Posted May 30, 2013 Sounds like you have the non airbag boss and are trying to fit it to an airbag (or used to be) car. Stick a pic up of the boss and the cowl behind the wheel Link to comment Share on other sites More sharing options...
berg Posted May 30, 2013 Share Posted May 30, 2013 It must be the wrong boss kit, maybe for a mk3 I fitted one on mine and it has a gap in it so it misses the big block connecter you are talking about then the standard horn wire which was connected the stock wheel to the horn push button and job done Link to comment Share on other sites More sharing options...
Fizzy T Posted May 30, 2013 Share Posted May 30, 2013 Has anyone fitted an aftermarket wheel and retained the cruise control stalk? Link to comment Share on other sites More sharing options...
Josh Posted May 30, 2013 Share Posted May 30, 2013 I had the same issue (http://mkivsupra.net/vbb/showthread.php?269339-Steering-wheel-replacement) and I ended up getting a new boss from Driftworks. Link to comment Share on other sites More sharing options...
Rich.2211 Posted May 30, 2013 Share Posted May 30, 2013 (edited) I have also had the same issue. I had to bite the bullet and buy the HKB boss that Driftworks sell. It fits perfectly and clears that connector block. Mine is also a non air bag model Supra. I've heard a few stories of people buying a boss from Demon Tweeks for the mkiv Supra and they don't fit. Edited May 30, 2013 by Rich.2211 (see edit history) Link to comment Share on other sites More sharing options...
Guest jkyle69 Posted May 31, 2013 Share Posted May 31, 2013 Thanks for the help and advice, I definitely have a non-airbag car without cruise control (1993 car ), so the demon tweaks boss is going back and have bought the HKB boss from Driftworks instead Link to comment Share on other sites More sharing options...
Rich.2211 Posted May 31, 2013 Share Posted May 31, 2013 Thanks for the help and advice, I definitely have a non-airbag car without cruise control (1993 car ), so the demon tweaks boss is going back and have bought the HKB boss from Driftworks instead Link to comment Share on other sites More sharing options...
sideexitsupra Posted May 31, 2013 Share Posted May 31, 2013 When I fitted mine I got an airbag delete boss kit off Whifbitz. Included the little plug that goes in where the airbag was connected. Link to comment Share on other sites More sharing options...
