Kaan W Posted May 21, 2013 Share Posted May 21, 2013 Is there a minimum recommended clearance from the rear wheel to the spring and does this gap decrease when suspension compresses? Im just tryng to figure out how much wider I can go with my tires but I dont want them to scrub the spring over bumps etc. Thanks in advance.. Link to comment Share on other sites More sharing options...
spikedjack Posted May 22, 2013 Share Posted May 22, 2013 Being a double wishbone setup, it should not move closer to the strut under compression, the whole idea of double wishbone is to avoid inducible camber upon loading. As long as there was sufficient clearance (10mm or so) I wouldn't worry too much Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 Being a double wishbone setup, it should not move closer to the strut under compression, the whole idea of double wishbone is to avoid inducible camber upon loading. As long as there was sufficient clearance (10mm or so) I wouldn't worry too much Ah ok I see, thanks for your help. Also in this picture the coilover angles out towards the bottom so how much extra width would you say I can go with a different wheel? Link to comment Share on other sites More sharing options...
spikedjack Posted May 23, 2013 Share Posted May 23, 2013 You've got another inch or two back spacing by that photo by the looks of it Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 You've got another inch or two back spacing by that photo by the looks of it Yeah I was trying to work out that if it was a 15" wheel where the inner lip would come into contact with the spring. I guess its trial an error unless theres an accurate way of working it out. Link to comment Share on other sites More sharing options...
mark newman Posted May 23, 2013 Share Posted May 23, 2013 its all about back space very easy thing to work out. Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 So I just mark on the coilover where the lip of a 15" wheel would reach then measure from that point to the hub face minus 10mm or so for clearance? Link to comment Share on other sites More sharing options...
mark newman Posted May 23, 2013 Share Posted May 23, 2013 well if i understand you right , that would give you the back space that you will need on the wheel yes. Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 well if i understand you right , that would give you the back space that you will need on the wheel yes. But then I would need to work out the section width on the tire I suppose. Thanks for your input. Link to comment Share on other sites More sharing options...
mark newman Posted May 23, 2013 Share Posted May 23, 2013 i think a 8'' back space will be good. Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 With the arches I have bonded on I can fit a maximum of 28" tall tires with some slight work underneith and lifting the car right up which allows me to fit a 325 tire which is more than good enough. But for the street I want the widest 26" tall tire I can find on an 18" wheel but I cant seem to find anything wide enough to not use spacers. Link to comment Share on other sites More sharing options...
mark newman Posted May 23, 2013 Share Posted May 23, 2013 have a set made in the states , then you could have what you want . Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 have a set made in the states , then you could have what you want . Its not the wheels its the tires mate. I'll probably go with a 345/35/18 and stick with the wheels I have with a smaller spacer. I didnt really want a spacer or hidden wheels either.... Link to comment Share on other sites More sharing options...
mark newman Posted May 23, 2013 Share Posted May 23, 2013 Its not the wheels its the tires mate. I'll probably go with a 345/35/18 and stick with the wheels I have with a smaller spacer. I didnt really want a spacer or hidden wheels either.... its not the wheels it the tyres , the tyre's go on the wheels Kaan, you got to get the right wheels so the tyres will go where you need them to be . you dont do a back space on a tyre , Link to comment Share on other sites More sharing options...
Kaan W Posted May 23, 2013 Author Share Posted May 23, 2013 its not the wheels it the tyres , the tyre's go on the wheels Kaan, you got to get the right wheels so the tyres will go where you need them to be . you dont do a back space on a tyre , Ok thanks, I was thinking if I workout the back spacing to allow the wheel to sit just next to the spring then a fat tire will rub the spring so I need to work out how much extra the tire bulges out to get the correct back spacing for the wheel. I think I will need spacers no matter what to fill the arches so it should be fine. Link to comment Share on other sites More sharing options...
