Bent wheel nut
Guest suprageek
Guest suprageek
Anyone any idea how i could get a bent wheel nut off its really sof t metal and it was on so tight it bent when i was trying to get it off, ill post up a pic, thanks
Guest suprageek
A good pic close up in the wheel will really help.
Is it a steel nut or aluminium alloy ?
I think its a mild steel one, there the crappy ones you get free when you buy alloys
It's pretty damaged though dave. If he ruins it much more, he will be in seriously problem-street.
You definitely need to check the material first. I would try and use removal tools before welding, that's a last attempt really.
