Noz Posted February 23, 2013 Share Posted February 23, 2013 Best place for location, going to use a single sensor. Link to comment Share on other sites More sharing options...
Hartmann Posted February 23, 2013 Share Posted February 23, 2013 a 1/2 to 1 inch from the ex.port at cyl. 6 Link to comment Share on other sites More sharing options...
Noz Posted February 23, 2013 Author Share Posted February 23, 2013 Wouldn't that just give readings from cylinder 6? Link to comment Share on other sites More sharing options...
Scott Posted February 23, 2013 Share Posted February 23, 2013 Wouldn't that just give readings from cylinder 6? The hottest cylinder Link to comment Share on other sites More sharing options...
Noz Posted February 23, 2013 Author Share Posted February 23, 2013 Awesome. Perfect then Why is that then? Never heard that before. Link to comment Share on other sites More sharing options...
Scott Posted February 23, 2013 Share Posted February 23, 2013 Awesome. Perfect then Why is that then? Never heard that before. Common knowledge. Think it's probably something to do with the way the exhaust manifold is routed. That's the reason the scoops on the UK spec aim at the no5 & no6 area of the manifold/head. Link to comment Share on other sites More sharing options...
Noz Posted February 23, 2013 Author Share Posted February 23, 2013 I've never really looked into it so never read anything, if it's to do with the design of the exhaust manifold, would an after market one make a difference? As the flow wouldn't be the same as the OEM manifold. Link to comment Share on other sites More sharing options...
Scott Posted February 23, 2013 Share Posted February 23, 2013 I've never really looked into it so never read anything, if it's to do with the design of the exhaust manifold, would an after market one make a difference? As the flow wouldn't be the same as the OEM manifold. I honestly don't know. Everyone uses the 6th runner and everyone sings from the same hymn sheet that knows about it. Quite happy to be proved wrong, my EGT is in the 6th runner as it was in JPs car (LeeP put it there, I believe at Ryan G's recommendation... although I could be wrong). As I said, MrT put the bonnet scoop at the 6th runner, so there was clearly something there as standard. It may even have been intake related, firewall related, coolant related, oil flow related, etc, etc, etc. All speculation from my part. There are a few members who have gone to the trouble of putting 6 EGT probes in, for racing etc, just so that they can monitor exactly what's happening... and to my knowledge they all put forward that the 6th cylinder is the hottest. Link to comment Share on other sites More sharing options...
Wez Posted February 24, 2013 Share Posted February 24, 2013 On stock turbos the number 6 runner, on singled motor I go just before turbo in the collector, some mount in the turbo Link to comment Share on other sites More sharing options...
Swampy442 Posted February 24, 2013 Share Posted February 24, 2013 On stock turbos the number 6 runner, on singled motor I go just before turbo in the collector, some mount in the turbo Yep, my set up has it in the turbo exhaust housing. In guessing the 6th cylinder is the hottest because its furthest from the water pump/rad and close to the bulkhead so theres not much airflow round the back of the engine? Link to comment Share on other sites More sharing options...
Scott Posted February 24, 2013 Share Posted February 24, 2013 Yep, my set up has it in the turbo exhaust housing. In guessing the 6th cylinder is the hottest because its furthest from the water pump/rad and close to the bulkhead so theres not much airflow round the back of the engine? That makes sense, it'll definitely be something like that Link to comment Share on other sites More sharing options...
