my slow supra build, slow it has been lol
scott23
just like to take the time to add some pictures of my slow supra build, hope you like the pictures
parts list for the car fitted.
body kit as known as a gt300 top secret kit this is the cheap version as i dont have a endless money pit, it arrived to the body shop and think carboard would have been stronger.
as you can see from the picture none of it aligned up but thanks to the time spent mere 50/60 hrs it was on but look like it had a bad case of cellulite. 100 hrs went into smoothing and strenghtening the kit before respray.
thought id be different so searched every where for a carbon aero roof ( make it easy to carry as i struggle being in wheelchair)
found a place that ended up being local, made the moulds then out come was perfection.but sadly didnt fit the roof for 3 months and the carbon had decided to become out of shape so had to make another :innocent:
seibon carbon rear hatch with whifbitz rear plastic
seibon carbon bonnet
wheels ssr rims provided by whifbitz look great running 265/35/19 bridgestone front and 345/35/19 bridgestone rear
brakes :
ap 6 pot 356mm front
rotora 356mm rear
superstreet coilovers with the electronic damper motors (handy for me)
gear box:
standard a340e broke so decided to fit a 700 r4 think is the 4l60 gm box with manual shifter lovely box uptil 650hp and broke on rollers 3rd gear had let go. so i spoke to paul from whifbits where the car is at this moment of time. decided to go back to a340e from titan performance which say can handle 800 at the wheels so i shall see how this holds up on the 27th march with ryan at 2bartuning maps car
engine:
well at he time almost 5 years ago i decided to get hks t51 dbb and manifold
272 cams hks pulley wheels and cam belt
titan stage 4 head and head internals
crank has been polished
aftermarket rods and pistons from hks
with billet main caps and arp bolts
hks crank pulley
greedy inlet q45 throttle body
hks fuel rail and injectors 1000cc
3 fuel pumps and hardware
larger breather hoses and tank
racing alu radiator
greedy large intercooler
electronics
hks fcon gold ecu with race logic traction control unit(be for sell shortly)
gone over to the syvec ecu
greedy boost contoler
seats
cobra misano seats
well small description of the bits fitted hoping to update new pictures when its home but for now heres the build up pictures
thanks for reading
Wow that budy kit does look really thin...! Nice spec though, look forwards to seeing more photos..!
Ps. Does your cobra misano seats rub against the door card? I've recently fitted some but mine slightly rub on the door card..! Maybe I need to try different seat rails?
mine did as well what i did was put 2mm spacer washer on right side runners and it clears door card , do you fine your runners stiff mine are well stiff to move
Yes they are very stiff and most of the time they can only be adjusted once I am sit on them...! Its also a shame that they don't have the automatic reclining to make it easier to get to the back seats like the OEM ones..!
That kit is shocking in the fitment departments. Good luck on the build
it was but the finish is really well done been on car for bout 2.5 yrs now but anyone buying a cheap kit be prepared to spend at least 100hrs +
