Josh42 Posted February 26, 2012 Share Posted February 26, 2012 As above, what's recommended? Josh Link to comment Share on other sites More sharing options...
Josh Posted February 26, 2012 Share Posted February 26, 2012 36psi all round. I had 34 front, 32 rear. *awaits questioning* Link to comment Share on other sites More sharing options...
Wez Posted February 26, 2012 Share Posted February 26, 2012 I normally run 34psi on the rear and 36psi up front Link to comment Share on other sites More sharing options...
Josh42 Posted February 26, 2012 Author Share Posted February 26, 2012 Cheers fellas! Link to comment Share on other sites More sharing options...
Slicknick Posted February 26, 2012 Share Posted February 26, 2012 Another 36 front 34 rear here Link to comment Share on other sites More sharing options...
Tyson Posted February 26, 2012 Share Posted February 26, 2012 Running standard tyre sizes I would run 36 all round, if people can provide evidence in the way of results and figures as to why they run lower pressures then I am all ears. But all I can see you doing is getting uneven wear, increasing the temperature of the tyres and making them more prone to blow out under extreme driving. Link to comment Share on other sites More sharing options...
Slicknick Posted February 26, 2012 Share Posted February 26, 2012 Running standard tyre sizes I would run 36 all round, if people can provide evidence in the way of results and figures as to why they run lower pressures then I am all ears. But all I can see you doing is getting uneven wear, increasing the temperature of the tyres and making them more prone to blow out under extreme driving. Well when I ran 36 at the rear the center of the tyres wore much faster than the sides, i dropped the pressure 2psi and now they are wearing evenly. Link to comment Share on other sites More sharing options...
Tyson Posted February 26, 2012 Share Posted February 26, 2012 Well when I ran 36 at the rear the center of the tyres wore much faster than the sides, i dropped the pressure 2psi and now they are wearing evenly. Sounds like your car needs a geo setup, as with 36 in mine I get nearly perfect wear across the tyre. Link to comment Share on other sites More sharing options...
Slicknick Posted February 26, 2012 Share Posted February 26, 2012 Had a full Geo setup done last week by WIM. So you could well be right, I will have to see how they wear now Link to comment Share on other sites More sharing options...
