David Reid Posted February 6, 2012 Share Posted February 6, 2012 I have now sourced a nice replacement engine for my supra but will be giving it a refresh before fitting it. I will be changing the bottom end bearing and fitting ARP, Main, Big end and head studs together with a new oil pump. I am currently considering if I just refit a standard Toyota head Gasket or I go for a good aftermarket one. Note I dont want to fit a cheap metal cometic ect as I have seen many problems with them not sealing properly on other engines. I would either use a HKS or cosworth, but I am not sure if even need an uprated one as I was suprised to see the standard gasket is a steel multilayor type. I will hopefully be running just over 600 bhp when it is all back together. So the choice, replacement Toyota gasket, or good aftermarket gasket? Let me know your thoughts? Link to comment Share on other sites More sharing options...
JamieP Posted February 6, 2012 Share Posted February 6, 2012 OEM head gasket. Link to comment Share on other sites More sharing options...
jay200bhp Posted February 6, 2012 Share Posted February 6, 2012 OEM all the way Link to comment Share on other sites More sharing options...
David Reid Posted February 7, 2012 Author Share Posted February 7, 2012 thankyou guys, I''ll just use the stock one that will come in the full Toyota engine gasket set Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 9, 2012 Share Posted February 9, 2012 I have a new OEM TT head gasket I have found. Link to comment Share on other sites More sharing options...
