Notts_TT Posted January 18, 2012 Share Posted January 18, 2012 Hi Took to Supra for a quick Blert today to see how it runs after full BPU. I noticed the afr reads 10 when cold, 12.5 at warm idle, 11 when hard accelerating and 14.5 when crusing at 60... Also i fitted a 1 bar rr and have wired in a aem truboost, i havent touched the boost controller yet but noticed it was boosting at 16.5 ish psi, is there no need for the truboost ???, should i adjust gain feature ? Please let me know what you guys think... Thanks [GRIN][/GRIN] Link to comment Share on other sites More sharing options...
Littler Posted January 18, 2012 Share Posted January 18, 2012 Definitely going to head over for a run in this now it's up and going! How's that arches coming on? Link to comment Share on other sites More sharing options...
Notts_TT Posted January 18, 2012 Author Share Posted January 18, 2012 Just needing some wrap for arches and there going back on :-) Pop over when your ready pal :-) Can anyone shed light on my questions Thanks Link to comment Share on other sites More sharing options...
fastcar Posted January 18, 2012 Share Posted January 18, 2012 whats 16.5 psi in old money? Link to comment Share on other sites More sharing options...
Josh Posted January 18, 2012 Share Posted January 18, 2012 whats 16.5 psi in old money? 1.13 bar. Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 That's without touching the boost controller, as it comes out of box ? Should I just set gain to help it spool quicker and leave boost setting as 1.1 bar of boost is good ya :-) What about the afr levels ?? Link to comment Share on other sites More sharing options...
Robzki Posted January 19, 2012 Share Posted January 19, 2012 The afr's don't look right to me, mine runs 12-13ish cold then pretty consistent 14.5-14.8 when warm, idle or on a run. Possibly o2 sensors? Personally I would check the fuelling before 'blerting' anymore R. Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 Do I need a rolling road company to check this ? Link to comment Share on other sites More sharing options...
Robzki Posted January 19, 2012 Share Posted January 19, 2012 Depends on how mechanically minded you are. I'd try a search on here for 'o2 sensors' It has been covered numerous times and are prone to failure at this age. Link to comment Share on other sites More sharing options...
Robzki Posted January 19, 2012 Share Posted January 19, 2012 who did the 'full bpu'? Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 That would be I :-) Link to comment Share on other sites More sharing options...
Robzki Posted January 19, 2012 Share Posted January 19, 2012 Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 Run down: Twin decat Full stainless nur spec Walbro Hks fcd Autobahn 88 fmic 1 bar rr Platinum plugs Aem tru boost Aem afr Blitz sus filter Think that's it ? Link to comment Share on other sites More sharing options...
Scott Posted January 19, 2012 Share Posted January 19, 2012 I get around 11-12 cold start. 13.5-14.5 once warmed up. On a run around 14-15. Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 I'm a tad rich then ?? Link to comment Share on other sites More sharing options...
Scott Posted January 19, 2012 Share Posted January 19, 2012 Make sure you are checking the warm idle when the car is actually warm. It takes a lot longer to get to full temp than most people think it does. Link to comment Share on other sites More sharing options...
Ian C Posted January 19, 2012 Share Posted January 19, 2012 Your cruise values are spot on, so I'd expect warm idle to be correct as well. The oil temps have to be around 50degC before it drops into closed loop. If your O2 sensor is "bouncing" around a value then it's in closed loop, if it's a steady value it's still in open loop. Also, there isn't really such a things as a "1 bar restrictor ring", as each car can be different. You probably need a narrower ring if you really want 1bar of boost, but I wouldn't worry about it as you'll just run richer and have less power Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 19, 2012 Share Posted January 19, 2012 Now turn the boost controller up to 1.2 bar and enjoy !! Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 Cheers guys. Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 Left it idling today for 30 mins while i was working on it and the afr reached 13.1 and stayed steadyish... Closer eh Link to comment Share on other sites More sharing options...
monsween Posted January 19, 2012 Share Posted January 19, 2012 I'm a tad rich then ?? Better than a tad poor Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 Better than a tad poor Link to comment Share on other sites More sharing options...
Ian C Posted January 19, 2012 Share Posted January 19, 2012 Left it idling today for 30 mins while i was working on it and the afr reached 13.1 and stayed steadyish... Closer eh Hmmm that's not right. Check the voltage output on your o2 sensor Link to comment Share on other sites More sharing options...
Notts_TT Posted January 19, 2012 Author Share Posted January 19, 2012 What should it be pal ??? Link to comment Share on other sites More sharing options...
Scott Posted January 19, 2012 Share Posted January 19, 2012 What should it be pal ??? I think mine used to sit around 14-14.5, could be a little off though. Link to comment Share on other sites More sharing options...
