UK TT v NA rear spring rate
Neil-NA
I read that too, they are softer so in theory should have. My springs are way too soft!
I take it you are still on stock NA springs?
I found stock NA springs soft then the tein NA springs way too hard, but i want to go even softer now if thats what the UK TT springs will offer.
So you want even softer than the NA springs? Do you want my mattress? :D
I can tell you that a set of UK rear springs will raise the back end around 10mm over a set of J-Spec TT rear springs. Can't say that I found the J-Specs much firmer though.
I don't know for certain, but I doubt there's much difference between J-Spec N/A and TT rear springs.
Thanks for the info bud, i might just take a gamble and get some, if that doesn't work i will have to get some made.
