5 speed w58 paddle clutch
barneybrendan
it will fit and the tunnel only needs replacing if you are fussy.mine was originaly an auto and the tunnel was just trimmed for the gear lever.
http://www.mkivsupra.net/vbb/showthread.php?260289-Auto-to-manual-tunnel-is-it-needed
i never realized until i started breaking the car,never had any extra heat ,noise or fumes as the rubber fitted fine and hid it away.
extras you need
clutch
clutch pedal
master cylinder
R154 and W58 have the same number of splines and when my stock clutch destroyed itself at Teesside we bought a stock W58 replacement Im sure, but I remember us phoning around asking for either.
I'll check with the bank manager whether I can afford this or not, hope she says yes lol :D
Barney, Im probably going to take this off your hands, its just a little mis-timed atm, so can I put a £20 deposite just to hold it for a couple of weeks, pending some measurements just to make sure it will fit my R154, if I measure the inside and outside diameter and confirm the number of splines I have ?
