Welshbuddy's Supra Build, Engine Conversion++ with videos.
welshbuddy
 Share
  • Replies 256
Posted Images
In between doing jobs on my car i did a bit more on Welshbuddy's. I removed the air con rad and pipes and a few other things that are not need for the TT engine.
Can not do much now untill the clutch arrives come on Paul :p
A quick pic to show Welshbuddy there is paint under all that grime lol
cheers mate :), hope so mate :)! got that spoiler on that :)?
not yet fella got to wait for my new bootlid to arrive be for i put it on. I have a carbon one on there at the moment that has gone milky so taking it off a replacing with OEM.
Did you get a competition flywheel to go with with the clutch?
This weekend cracked alot out!
started by cleaning the bay out, 2 cans of carb cleaner gone, :p. Spotless before we dropped the engine in, other wise it would have been a complete nightmare! we came across few problems....
( should have taken more pics this weekend, ( but i didn't) :(!
anyway moving on:
1/cleaned the engine bay
2/New competition clutch fitted.
3/removed Soarer Throttle cable ,ecu,
4/Lifted and Fitted the 1jz - Took abit of persuading.
5/Came across a few complications, Fuel line ,gearbox connections ( If anybody could help with the electrics , got some questions :) ) -cheers
6/ Started to Refit power steering pump and lines
7/ and all the other little bits - Ignition and such.
8/ Fed the Loom through car
Edited by welshbuddy (see edit history)
ok need help with the gearbox wiring, as the Soarer had a automatic gearbox, we cut the Loom that goes to it as we didn't need it, so we now have the problem of wiring the gearbox up.
these are the plugs from the N/A loom that went to the gearbox.
need to know what they control if they go to the gearbox. And because it is on the N/A engine still , how far does the Loom go under the manifold?.
thanks daz.
Wiring is almost cracked mate. Front Mount is in place, i had to use the stock rubber inter cooler pipe on the turbo side but as soon has the Tig Welder is here i will get joe to custom fit the pips for you. Not a lot left to do now mate :)
mate im well excited , tig welds the intercooler pipes :)?, with the 3" hard pipe with bov, will be awesome :), see you weekend mate
 Share
