Error 42 guaranteed fix?
mrmyagiii
Hi i`m having an error code 42. The speed sensor thingy. My search resulted in me rewiring some wires behind the speedometer but that didn`t help. Lately the speedometer drops to 0 km/h at random, tapping the dashboard is a good temporary solution but i find myself tapping the dash to much these days.
Symptoms:
Speedo drops to 0 km/h at random
Slip cont off starts flashing random
O/D off starts flashing after 3mins or so
Cruise Control doesn`t work
What to do to make this all stop? I heard the speed sensor is usually not the problem but the odometer electronics? Should i replace the odometer and see where that takes me?
Yes, it does act as a buffer. That might even have been one of my posts. :) However, the odometer is downstream of the speedometer. Tinkering with the odometer will have no effect on the speedometer, and if the speedometer has an error (e.g. needle drops to zero when it shouldn't) then this should be fixed first.
Well, if by tapping the speedo fixes the problem, I'd look and putting a replacement speedo unit in. If the speedo drops to 0 chances are theres a promlem with the speedo's electronic gubbins and this may affect everyting else as it all connected together!
Like heckler said. If tapping the speedo temporarily fixes the issue then you've probably got a marginal electrical connection either going into the speedo cluster or within the cluster itself. Leave the odo alone, that won't help you fix this. All your symptoms (slip cont, O/D off etc) are a result of the speedometer not picking up the speed correctly. Fix the speedo and everything should work again.
So, tapping the odo makes the speedo needle behave properly (albeit temporarily)? How odd. The speedo output feeds the odo input, not the other way around, hence the odo function is dependent on the speedo. The speedo isn't dependent on the odo.
Of course, if the loom's been hacked around then anything's possible. You could try another speedo cluster if you can get hold of one, failing that return the wiring to stock like you said.
