Sted Posted November 2, 2011 Share Posted November 2, 2011 Ballasts or the Bulb ??? When my HID's have been on for a long time The near side one goes out. If I turn them off and then back on again it will light up again but then goes straight out again. Any idea's if its the ballast or the bulb that is failing ? or should I just buy a new set Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 3, 2011 Share Posted November 3, 2011 Does it happen when you go over a bump or anything? it could be loose/dodgy connections mate, had the same problem on mine...eventually after switching it on and off the drivers one just didnt switch on until i opened the bonnet gave the connector a tap and it flickered to life. Just unplug it, clean it out, blow out any dust and push it back into place, FIRMLY, not too much as to break it....never had a problem since. If that doesnt work, try swapping the bulbs round on the ballasts, if the problem persists in the same light then its the ballast, if the problem persists in the other light then its the bulb, HTH Link to comment Share on other sites More sharing options...
Guest Supra_boy Posted November 3, 2011 Share Posted November 3, 2011 As said above, swap ballasts around then swap bulbs. It it comes on for a while then it should'nt be the bulb as it would'nt ignite. Try the swapping them about first. Link to comment Share on other sites More sharing options...
probrox Posted November 3, 2011 Share Posted November 3, 2011 One of mine turns on and flickers and then goes out again. When I switched them around it was the ballast causing the problem. Link to comment Share on other sites More sharing options...
Sted Posted November 3, 2011 Author Share Posted November 3, 2011 I think its the ballast, its staying on now for short journey's but then any longer trips and its gone off again. I've ordered a new set of HID's, I'm just going to replace them . Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 10, 2011 Share Posted November 10, 2011 Ended up doing that in my daily, just cba with the hassel of sending it back and forth etc...new set bang em in, job done lol Link to comment Share on other sites More sharing options...
j_jza80 Posted November 12, 2011 Share Posted November 12, 2011 If the Ballast earths on the bodywork, check to see if it has corroded. A VERY common problem apparently. Happened on an old Supra of mine, it kept killing the damn battery! Link to comment Share on other sites More sharing options...
