Help on removing TRD rear wing
SamuraiFlash
Hi Guys,
I have decided to remove my TRD rear wing and replace it with an OEM one. So far I am having issues removing it :rolleyes:
I have removed the plastic trim from the boot lid and I can see the 4 bolts, two on either side. Now I have tried to get to the bolts with a spanner and it just isn't happening. There is also some glue like substance over the bolts.
My question is what do I need to unbolt the spoiler off?
A socket set ;) 10 mm and a rachet
Get someone to hold the wing while you undo the bolts, also might be
easier to remove the centre section then your can remove each upright
individually
If the uprights have been stuck onto the tailgate with silicon its much easier to get them off
if you remove the centre section
If your stuck bring it to me and i'll fit the o/e wing as well, you can collect your ATF and
front spoiler at the same time ;)
Hi Guys,
I think if you need to ask that question, then you need to stay well away from any mechanicals on the car :D
I have a Halfrauds advance ratchet set and I cant get to the nuts. I'll come and see you tomorrow dunk :)
Step away from the toolbox Kamal :D
Dont forget to bring your o/e wing with you and your wallet full of cash and i'll sort you out ;)
What time are you coming ? i can meet you in the pub car park as before
LOL :D
Ok dunkster I'll meet you in the pub car park for 12? is that ok with you?
Edited by SamuraiFlash (see edit history)
