TESCO vs OPTIMAX
Ewen
  • Replies 87
99RON is available in other countries so it's not like it's not out there...
But TESCO are only testing the waters as such to see if there would be any demand...Tesco clubcard points and 99RON fuel would get me buying :)
Yup - worked on me! I don't know whether it's the placebo effect, but the car does seem to run smoother since I switched over.
without datalogging knock events or the igntition timing the ECU settles to, means that some of the effect might indeed be placebo.
At least the Tesco pumps proudly display the RON value, unlike Shell that depends on rumours and innuendo.
FWIW I find this 99RON stuff better than any branded 97RON.
i,m in maidstone, kent, are there any such pumps near, tried the local ones and no good!!! where in the south r you peeps getting it?
You didn't *have to* fill up though...
Anyway, I pretty much only use Ultimate cos there's no shell stations on my commute route.
nope, I didnt...but being the lazy git that I am, I have no choice but to fill up..... :)
I use the one in Thurrock mate.
Do a search here and you'll find the list of Tescos that do it. I think there's one closer to you still.
i've found BP Ultimate to be slightly better than Optimax, very close call sometimes though. I would happily use Tesco's 99 if they ever get it up here :swear: if it says 99 ron on it and conforms to BS etc standards, then i don't care if Netto or Aldi sell it!
yup, had to fill up with ultimate yesterday since I was completely out of fuel......
dont like it...
Cheers fella, will give that a miss but will try the tesco's next time I need to top up.
Also out of the two optimax V tesco's
Has the fuel economy become better or worse since moving to Tesco's 99RON
cheers
Guest chiefvinso
I wrote to shell and they confirmed that their optimax product was 98 ron and that they do not have to state it by law on the pumps.
So in brief, optimax is 98 ron hope that helps. :eyebrows:
I did the same and got the same result :) Of course, it could be a big conspiracy theory and it's in fact 95ron by the time it reaches the pumps :rolleyes: :read:
-Ian
Guest chiefvinso
-Ian
Thats why I wrote, however they did also state in the reply that as long as a certain bs :blahblah: was on the pump they didnt have to put the ron. Of the optimax pumps I have used I havent seen a BS on them either - so it could be a conspiracy!! :eek: lol
