Help I Am Hot
gregsupra4
Please can someone let me know where the fuse might be for the Air Con.
All the lights work on the heater control panel but the clutch on the air con pump does not kick in, I have removed the belt and checked the unit and it all spins ok and when I put power into the wire leading to the clutch it kicks in.
hOPING TO GET A REPLY SOON AS MY ICE CREAM IS GONNA MELT !!!!!! :tumble:
Hi gas is not the problem it is that when I push the AC switch on the control panel the clutch does not kick in on the air con comperssor.
No kick in = no cold air.
So I need to find the fuse or relay that controls this when I hit the AC switch.
if the gas gets low in the supra, it stops the system from working by not engaging the clutch ;)
Yep - have a look in the sight glass in front of the radiator to see if there is any refigerant in there. If not, you wil need it re-gassed. It will probably be worth having the system dye checked for leaks as this is a high pressure system.
Ooooooh - That's what that's for!
