Noz Posted July 9, 2011 Share Posted July 9, 2011 Im gonna be using 2x sandwich plates and was wondering how they fit onto the car. Hopefully this isn't a silly question. Tried searching just cant find any info. The plates dont have any threads so was wondering how they fit. Link to comment Share on other sites More sharing options...
Bailey. Posted July 9, 2011 Share Posted July 9, 2011 Iirc I went to hose and hydraulics and bought a 1/2 inch male/male, I may be wrong. Link to comment Share on other sites More sharing options...
bignum Posted July 9, 2011 Share Posted July 9, 2011 What filter will you be using? Link to comment Share on other sites More sharing options...
Noz Posted July 9, 2011 Author Share Posted July 9, 2011 standard filter. shall i put pics of plates up? Link to comment Share on other sites More sharing options...
Bailey. Posted July 9, 2011 Share Posted July 9, 2011 Yes Link to comment Share on other sites More sharing options...
bignum Posted July 9, 2011 Share Posted July 9, 2011 So you`re mounting to plates together?, will you get a filter on also, theres not much room down there at the best of times, i know because i got my arm stuck this afternoon while doing an oil/filter change lol. Link to comment Share on other sites More sharing options...
Scott Posted July 9, 2011 Share Posted July 9, 2011 You might struggle to get the filter on there unfortunately. I've heard reports that it JUST fits but I've not given it a go yet... will be soon enough. You don't need anything specific for using 2 sandwich plates. Just buy 2 of them suited for the supra, they will come with the centre unions required. Just bolt them onto each other and the job is done. I would have a look into a shorter K&N filter though, to be on the safe side (for all it costs as well.) Link to comment Share on other sites More sharing options...
Bailey. Posted July 9, 2011 Share Posted July 9, 2011 I have 2 plates and all fits fine, get the kit and worry about it nearer the time, it's straight forward. Link to comment Share on other sites More sharing options...
Scott Posted July 9, 2011 Share Posted July 9, 2011 Did you not take out the stock oil cooler though? Link to comment Share on other sites More sharing options...
Bailey. Posted July 9, 2011 Share Posted July 9, 2011 Yes that is true, if he's using 2 plates he must be too, no need for more than 2 outlets otherwise (oil temp/pressure) is that what your planning noz? Link to comment Share on other sites More sharing options...
Scott Posted July 9, 2011 Share Posted July 9, 2011 Yes that is true, if he's using 2 plates he must be too, no need for more than 2 outlets otherwise (oil temp/pressure) is that what your planning noz? I think removing the stock cooler is a fairly new mod. Previously only serious modders would have done it. 2 plates has been a mod for as long as I can remember. Sometimes you need 2 oil temp & pressure ports (one for each gauge and 1 of each for the ECU input). Could be a multitude of reasons really. Link to comment Share on other sites More sharing options...
Bailey. Posted July 9, 2011 Share Posted July 9, 2011 Ahhhh, I didn't realise that, do na's have oil coolers too? Link to comment Share on other sites More sharing options...
Scott Posted July 9, 2011 Share Posted July 9, 2011 Ahhhh, I didn't realise that, do na's have oil coolers too? Not sure, I can't see any reason why not but stranger things have happened Link to comment Share on other sites More sharing options...
Noz Posted July 10, 2011 Author Share Posted July 10, 2011 NA's dont have oil coolers. Running without boost doesnt require them. NA-T will require an oil cooler IMO so I went and got one Blue plate is for turbo feed (and oil temp / pressure gauge) and grey is (obviously) for my oil cooler. There is loads of room for 2x plates but visually I can't see any way to secure the plates. Link to comment Share on other sites More sharing options...
Noz Posted July 11, 2011 Author Share Posted July 11, 2011 bump Link to comment Share on other sites More sharing options...
djg99 Posted July 11, 2011 Share Posted July 11, 2011 (edited) Have you not got the thread that goes in the middle of the blue plate?? I've got one but not fitted it yet looks like this Edited July 11, 2011 by djg99 (see edit history) Link to comment Share on other sites More sharing options...
Bailey. Posted July 11, 2011 Share Posted July 11, 2011 Mate just wait Tlill it's all part, all will be clearer then! Link to comment Share on other sites More sharing options...
Stan Posted July 11, 2011 Share Posted July 11, 2011 I got one of those threads in the middle as well, I assumed that is what kept it all together Link to comment Share on other sites More sharing options...
Noz Posted July 11, 2011 Author Share Posted July 11, 2011 nope dont have one of them. the inside of the plate doesnt even have a thread in it. any idea where I can get one of those, or the dimensions? I have cnc's I could just make one out of 316 stainless if i knew the dimensions. I just need dimensions for filter, i spose if I just buy a filter and measure that I just need to replicate an adapter??? Link to comment Share on other sites More sharing options...
d-_-b Posted July 12, 2011 Share Posted July 12, 2011 nope dont have one of them. the inside of the plate doesnt even have a thread in it. Both the plates should have them - the "threaded" bit in the center is what holds the plate to the car. The insides of the plates arnt threaded - the "plug" with the thread on like you can see in dig's pic has is externally threaded one end, then smoother outer / threaded inner on the other end. The smooth end sits inside of the plate and screws down onto the external thread where your oil filter would mount to. The oil filter would then mount to the externally threaded part. In your case you would need 2 of these adaptors, the one attaching to the externally threaded part of the other. Without either they wont be "mountable" Link to comment Share on other sites More sharing options...
Noz Posted July 12, 2011 Author Share Posted July 12, 2011 (edited) ok problem solved. im going to make an adapter with some cnc super skills. anyone know what thread the oil filter uses? i think its 16UN at a check measure. il make a few SS adapter im sure will be useful. im going to make a double adapter, so for 2x sandwich plates ur only need one straight adapter. so any ideas on the oil filter thread? my gauges at work r all being used so i cant check. edit: problem sorted, made some new 316 adapters. Edited September 5, 2011 by Noz (see edit history) Link to comment Share on other sites More sharing options...
imi Posted March 21, 2012 Share Posted March 21, 2012 NA's dont have oil coolers. Running without boost doesnt require them. NA-T will require an oil cooler IMO so I went and got one Blue plate is for turbo feed (and oil temp / pressure gauge) and grey is (obviously) for my oil cooler. There is loads of room for 2x plates but visually I can't see any way to secure the plates. So there is enough room for 2 plates + the Stock Oil Filter? imi Link to comment Share on other sites More sharing options...
Noz Posted March 21, 2012 Author Share Posted March 21, 2012 Yes. By mine is NA. I'm sure I saw that somewhere someone had used 3x plates. Bit OTT for my liking. I currently have one plate for turbo feed, and another for aftermarket oil cooler. I'm not sure what else is located in that area on the TT, easiest way is to have a look, I was able to judge it just by looking there was so much room. Link to comment Share on other sites More sharing options...
imi Posted March 21, 2012 Share Posted March 21, 2012 I see - with the TT it looks very tight - would be nice to hear from someone who has managed to get two plates and the stock filter fitted on the TT. Link to comment Share on other sites More sharing options...
