monza786 Posted July 9, 2011 Share Posted July 9, 2011 Hi Just wondering if anyone knows of any mobile or local toad Alarm specialists who can come to me as there a fault on the Siren since I got the car back from workshop It arms and disarms but no chirp or hazards lights nor does Alarm sound when I arm it with door open The idiot who put it in my car about a year ago won't answer My calls even tho I'm willing to pay The co is advertised on eBay it's called safe-n- sound so be aware He's been very unproffional about the whole thing and hs been Ignoring my calls and emails I've rang trading standards and informed them Anyway guys pls someone help Quote Link to comment Share on other sites More sharing options...
AJI Posted July 9, 2011 Share Posted July 9, 2011 The key fob has four buttons from memory (well most do). The bottom two turn on/off the silent activation/disarm of the system. But the silent arm/disarm should still activate the hazzards to give visual notice that the action has been done. So from this basis it sounds like you could have a loose connection somewhere. Try following the wires to see if anything is obviously out of place. Or even clean up any connections you can find to make sure its not a corrosion issue. I'm not an expert on this but I did watch the guy install my alarm a few years ago. Plenty of wires in the system to create a problem if anything were to come loose. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted July 10, 2011 Share Posted July 10, 2011 The key fob has four buttons from memory (well most do). The bottom two turn on/off the silent activation/disarm of the system. But the silent arm/disarm should still activate the hazzards to give visual notice that the action has been done. So from this basis it sounds like you could have a loose connection somewhere. Try following the wires to see if anything is obviously out of place. Or even clean up any connections you can find to make sure its not a corrosion issue. I'm not an expert on this but I did watch the guy install my alarm a few years ago. Plenty of wires in the system to create a problem if anything were to come loose. I have a toad ai606 or something like that but my bottom 2 buttons do nothing. Quote Link to comment Share on other sites More sharing options...
GINNO78 Posted July 10, 2011 Share Posted July 10, 2011 I have just has a AI606 fitted it only chirps when arming it...not disarming it......also paid for dual microwave proximity sensor and its crap it works but is pathetically quiet!! Like doing a squeaky fart!! The siren itsel isnt particularly loud either! Quote Link to comment Share on other sites More sharing options...
GINNO78 Posted July 10, 2011 Share Posted July 10, 2011 I have heard that if you have the pin number for the alarm you can enable features but I have no idea how it is done Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted July 10, 2011 Share Posted July 10, 2011 I have just has a AI606 fitted it only chirps when arming it...not disarming it......also paid for dual microwave proximity sensor and its crap it works but is pathetically quiet!! Like doing a squeaky fart!! The siren itsel isnt particularly loud either! Should chirp twice when arming & one when dissarming (or the other way around) you should be hearing chirps arming & dissarming anyway. Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted July 10, 2011 Share Posted July 10, 2011 Check the fused feed to the control unit, they occasionally blow when reconnecting the battery (if workshop had it off). If not, check the block connectors going into the unit. It's usually under the dash, near your left knee. Quote Link to comment Share on other sites More sharing options...
GINNO78 Posted July 10, 2011 Share Posted July 10, 2011 My installer said it only chirps on Arm but he should have set it to silent as its against UK legislation to have the alarm chirp......I dont know I just agreed with him and off he went......It unlocks the doors off the fob everything seems to work so sod it!! Quote Link to comment Share on other sites More sharing options...
AJI Posted July 10, 2011 Share Posted July 10, 2011 I have a toad ai606 or something like that but my bottom 2 buttons do nothing. Mine is also the Ai606. Mine is set up so that the top two buttons give 3chirps on lock/arm and 2chirps when open/disarm. If there is a door open or boot open then on lock there will only be one longer chirp sound as a warning that the vehicle is not fully closed. The bottom two buttons turn on/off the silent mode. This is usually for if/when you were to pull up outside your house at 2am for example and you don't want to cause a noise to surrounding sleeping neighbours. But on all cases the indicator lights should also flash to give a visual notice that the Ai606 has received an instruction. I can only assume that if none of the above is taking place then you have a loose connection somewhere or that the system has been set up with various options disabled. Be sure to check that once you have locked/armed the system that it is actually working to secure your car. ie. try to get in to it once locked/armed to check if the alarm goes off and immobiliser activates. You can turn on/off different options within the system by using the key in the ignition and following the manual that should have come along with the unit. Quote Link to comment Share on other sites More sharing options...
AJI Posted July 10, 2011 Share Posted July 10, 2011 just to add....if you don't have the operator manual then this link may be of use to you: http://www.eserviceinfo.com/downloadsm/17912/Toad_Ai606.html You can download instructions from this page. Quote Link to comment Share on other sites More sharing options...
monza786 Posted July 13, 2011 Author Share Posted July 13, 2011 Thanks guys it's at the garage now il try some of those things mentioned here. Quote Link to comment Share on other sites More sharing options...
