ADD Posted July 7, 2011 Share Posted July 7, 2011 Hi all I have got my Meister r suspension through now (massive thanks to Dr_jekyll) and have a local reliable garage to fit it for me and put an MOT on too, but as far as im aware the ride height will be pretty high as standard so ill need to find somewhere local to hampshire that can alter the height of the suspension for me! Does anyone have any ideas where i can go? Ad Link to comment Share on other sites More sharing options...
Parry_10 Posted July 7, 2011 Share Posted July 7, 2011 Hi all I have got my Meister r suspension through now (massive thanks to Dr_jekyll) and have a local reliable garage to fit it for me and put an MOT on too, but as far as im aware the ride height will be pretty high as standard so ill need to find somewhere local to hampshire that can alter the height of the suspension for me! Does anyone have any ideas where i can go? Ad have you thought about doing it yourself? its very simple and easy to alter the height, I fitted the same suspension to mine and messed about with the height until it sat how I wanted it to. All you need to do is jack the car up and use the two c spanners undo the ring at the bottom and twist it one way will lower it and the other will raise the height. I would advise a full geometry set up as well after youve done a few miles on them to settle them- I used wheels in motion cant fault them Chris Link to comment Share on other sites More sharing options...
ADD Posted July 7, 2011 Author Share Posted July 7, 2011 have you thought about doing it yourself? its very simple and easy to alter the height, I fitted the same suspension to mine and messed about with the height until it sat how I wanted it to. All you need to do is jack the car up and use the two c spanners undo the ring at the bottom and twist it one way will lower it and the other will raise the height. I would advise a full geometry set up as well after youve done a few miles on them to settle them- I used wheels in motion cant fault them Chris Thanks for reply pal, if its that simple then yes ill do it myself i think. where abouts it WIM? cheers ad Link to comment Share on other sites More sharing options...
Parry_10 Posted July 7, 2011 Share Posted July 7, 2011 it really is that simple mate, just make sure you measure the heights you set it to, so both the fronts are the same and both the rears are the same. I think its in buckinghamshire you can check by going on theyre website just type them in on google. If you didnt want to adjust them yourself they would do it there for you then do the geometry after Link to comment Share on other sites More sharing options...
ADD Posted July 7, 2011 Author Share Posted July 7, 2011 ok mate i might aswell have a go at it myself.... thanks for your help Link to comment Share on other sites More sharing options...
ADD Posted July 11, 2011 Author Share Posted July 11, 2011 To do this perry i'll have to undo the the suspension from hub assembly wont i? Link to comment Share on other sites More sharing options...
Homer Posted July 11, 2011 Share Posted July 11, 2011 Provided they are not seized (assuming the suspension was 2nd hand) you should be able to do it with the suspension on the car. Lowered it shouldn't be a problem, but you may need to put some spring compressors on if you're having trouble. It's you're unlucky the springs seats you need to grip may be in theat the same height as the upper arm, if that happens you'll need to remove the long bolt that secures the upper arm to the subframe, It's pretty easy but can be a fiddle on the passenger side due to the washer bottle. If the seats are seized it's a nightmare!! I had to cut mine off and rebuild, it's proving a rather expensive exercise Link to comment Share on other sites More sharing options...
Parry_10 Posted July 11, 2011 Share Posted July 11, 2011 you can do it with the suspension on the car thats how I did mine but as homer said it depends on the condition of the suspension as mine were brand new so it was really easy for me. when you jack the car up and have a look it should all come into place about what you need to do, if you get stuck just send me a pm mate Link to comment Share on other sites More sharing options...
ADD Posted July 11, 2011 Author Share Posted July 11, 2011 The suspension is brand new matey, I just can't see how you can alter ride height when the bottom of the suspension is bolted to the car. Link to comment Share on other sites More sharing options...
ADD Posted July 11, 2011 Author Share Posted July 11, 2011 you can do it with the suspension on the car thats how I did mine but as homer said it depends on the condition of the suspension as mine were brand new so it was really easy for me. when you jack the car up and have a look it should all come into place about what you need to do, if you get stuck just send me a pm mate Hi mate think I may need to take you up on that offer. Any chance I could grab ya number of ya don't mind? Ad Link to comment Share on other sites More sharing options...
Parry_10 Posted July 11, 2011 Share Posted July 11, 2011 no worries will pm you now Link to comment Share on other sites More sharing options...
Steve Posted July 11, 2011 Share Posted July 11, 2011 To adjust my HSD's you have to remove the bottom bolt that holds the strut to the lower support. Then adjust the strut to alter the height, refit the lower bolt then move tighten the lock ring down to lock it off. Link to comment Share on other sites More sharing options...
ADD Posted July 11, 2011 Author Share Posted July 11, 2011 To adjust my HSD's you have to remove the bottom bolt that holds the strut to the lower support. Then adjust the strut to alter the height, refit the lower bolt then move tighten the lock ring down to lock it off. Thats exactly how i can see the only way of doing it..... Link to comment Share on other sites More sharing options...
Parry_10 Posted July 11, 2011 Share Posted July 11, 2011 (edited) To adjust my HSD's you have to remove the bottom bolt that holds the strut to the lower support. Then adjust the strut to alter the height, refit the lower bolt then move tighten the lock ring down to lock it off. with the meister r's you dont need to unbolt anything just undo the bottom lock nut and you can lower or raise the suspension Edited July 11, 2011 by Parry_10 (see edit history) Link to comment Share on other sites More sharing options...
Steve Posted July 11, 2011 Share Posted July 11, 2011 with the meister r's you dont need to unbolt anything just undo the top lock nut and you can lower or raise the suspension On the HSD's the adjusting part is threaded so needs to be turned to raise/lower the suspension. Any pics of the Meisters? Link to comment Share on other sites More sharing options...
ADD Posted July 11, 2011 Author Share Posted July 11, 2011 with the meister r's you dont need to unbolt anything just undo the top lock nut and you can lower or raise the suspension This is good news Link to comment Share on other sites More sharing options...
Parry_10 Posted July 11, 2011 Share Posted July 11, 2011 On the HSD's the adjusting part is threaded so needs to be turned to raise/lower the suspension. Any pics of the Meisters? I havent got pics but its threaded as well but with them being brand new I could twist them just using my hands... Link to comment Share on other sites More sharing options...
Steve Posted July 11, 2011 Share Posted July 11, 2011 I havent got pics but its threaded as well but with them being brand new I could twist them just using my hands... Ah, got ya. Makes sense now Link to comment Share on other sites More sharing options...
Parry_10 Posted July 11, 2011 Share Posted July 11, 2011 its probably me making it hard to understand its hard to explain but looking at the pictures on the website I remember now all i did was loosen the bottom lock nut and then just twist the strut to raise/lower Link to comment Share on other sites More sharing options...
ADD Posted July 12, 2011 Author Share Posted July 12, 2011 Replaced and set up the rears in a couple of hours today, couldn't believe how easy it actually was (cheers perry) got to the fronts and I couldn't shift the suspension enough to get it out, realised that I'd need spring compressors to compress them by 2-3 cm and it would clear. So back in it tomo.... Enjoyable day doing it though. Ad Link to comment Share on other sites More sharing options...
Parry_10 Posted July 12, 2011 Share Posted July 12, 2011 Replaced and set up the rears in a couple of hours today, couldn't believe how easy it actually was (cheers perry) got to the fronts and I couldn't shift the suspension enough to get it out, realised that I'd need spring compressors to compress them by 2-3 cm and it would clear. So back in it tomo.... Enjoyable day doing it though. Ad nice one mate good to hear, but you dont need spring compressors you take out the long bolt at the back of the top suspension arm (easiest way imo) and on the passenger side you will need to remove the washer tank so you can get the bolt out, really easy though mate Link to comment Share on other sites More sharing options...
ADD Posted July 12, 2011 Author Share Posted July 12, 2011 nice one mate good to hear, but you dont need spring compressors you take out the long bolt at the back of the top suspension arm (easiest way imo) and on the passenger side you will need to remove the washer tank so you can get the bolt out, really easy though mate Oh ok mate I took the bottom bolt out and the drop link off along with the 3 top nuts but didn't see the long suspension arm bolt. Coz as I pull the whole unit down to take it out it gets jammed on the rear part of the spring. Link to comment Share on other sites More sharing options...
Parry_10 Posted July 12, 2011 Share Posted July 12, 2011 Oh ok mate I took the bottom bolt out and the drop link off along with the 3 top nuts but didn't see the long suspension arm bolt. Coz as I pull the whole unit down to take it out it gets jammed on the rear part of the spring. Ah ok you've gone about doing it the harder way lol, usually those drop links don't come off without rounding them off and damaging them to get them off so you need to get new ones, I guess you were lucky and yours were ok. Link to comment Share on other sites More sharing options...
ADD Posted July 12, 2011 Author Share Posted July 12, 2011 Ah ok you've gone about doing it the harder way lol, usually those drop links don't come off without rounding them off and damaging them to get them off so you need to get new ones, I guess you were lucky and yours were ok. I wouldn't have been able to lever the hub down to get suspension out if I hadn't of disconnected the drop link. Is there easier way then? Link to comment Share on other sites More sharing options...
Parry_10 Posted July 12, 2011 Share Posted July 12, 2011 Yes you would have all you have to do for the fronts is take out the one long bolt on the top suspension arm that's how's easy it is literally 15 minute job each side no need to remove drop links or use spring compressors Link to comment Share on other sites More sharing options...
