2JZ engine mounts
Swampy442
Check this out?
http://www.jzs147.com.au/forum/viewtopic.php?t=1420
I just searched 'Aristo engine mount removal' in Yahoo. They obviously bolt on from underneath but access may be from the end if the crossmember lifts out? Didn't seem to be an issue for the above guys though.
If all else fails, just get a Starret holesaw about an inch diameter and drill a hole through the crossmember floor! :D
Obviously you'll want to seal the holes when you're finished with flush rubber plugs. ;)
Are you SURE they aren't plugged already? Seems awfully shortsighted of Toyota to weld the crossmember in and give no access to the nuts.
Edited by Morpheus (see edit history)
Defo not screw in. I've been on the net having a search. Can't find anything decisive but quite a few people have replaced these with supra mounts and talk about bolting them in. It must be bolted to the subframe. Is there a section that needs to be removed to allow access?
Im hopping someone with some knowledge might come and help you with this.
