bobbywarne1983 Posted February 16, 2011 Share Posted February 16, 2011 Hi ya guys going to be doing a service on my car, and im going to need a water pump ( i have a 3.0 n/a) and a cambelt. where is best to get these parts from?? would a toyota dealer have them or will i have to look else where??? cheers guys. Link to comment Share on other sites More sharing options...
Geo Posted February 16, 2011 Share Posted February 16, 2011 Paul Whiffin Dude(Whifbitz) should be able to get them cheaper Give hime a ring? Link to comment Share on other sites More sharing options...
bobbywarne1983 Posted February 16, 2011 Author Share Posted February 16, 2011 quickest answer ever cheers buddy, im hoping to get a de cat from there so looks likeil be buying all three from him . thanks again. Link to comment Share on other sites More sharing options...
Scooter Posted February 16, 2011 Share Posted February 16, 2011 Is the pump leaking/gone? It's just that if it's not i'd spend the money on a new crank pulley over the water pump. Link to comment Share on other sites More sharing options...
Swampy442 Posted February 16, 2011 Share Posted February 16, 2011 You can get them on eBay but best to go with Toyota quality Link to comment Share on other sites More sharing options...
Iky Posted February 16, 2011 Share Posted February 16, 2011 FYI, stock toyota ones are made by a company called Aisin(sp) Link to comment Share on other sites More sharing options...
bobbywarne1983 Posted February 16, 2011 Author Share Posted February 16, 2011 well water was pissing out the back of the water pump and down the block, ive bought some core plugs, but i was thinking maybe just buy a whole new water pump just to be on the safe side. and i thought as il be changing that i have not a great idea of when the cambelt was last changed so changing that at the same time might be an idea. Link to comment Share on other sites More sharing options...
Scooter Posted February 16, 2011 Share Posted February 16, 2011 in that case it sounds more than reasonable to replace! Link to comment Share on other sites More sharing options...
Iky Posted February 16, 2011 Share Posted February 16, 2011 well water was pissing out the back of the water pump and down the block, ive bought some core plugs, but i was thinking maybe just buy a whole new water pump just to be on the safe side. and i thought as il be changing that i have not a great idea of when the cambelt was last changed so changing that at the same time might be an idea. I had exactly the same problem. There was a tiny hole in the plug which pissed out coolant down the side of the block making it difficult to determine the origin of the leak. It's a good idea to replace the o-rings on the tube as well if can. Link to comment Share on other sites More sharing options...
bobbywarne1983 Posted February 16, 2011 Author Share Posted February 16, 2011 I had exactly the same problem. There was a tiny hole in the plug which pissed out coolant down the side of the block making it difficult to determine the origin of the leak. It's a good idea to replace the o-rings on the tube as well if can. O-rings on the tube???? whats that? Link to comment Share on other sites More sharing options...
