Guest joey Posted February 11, 2011 Share Posted February 11, 2011 Hey all, Does anyone know the size of 2jz-ge & 2jz-gte pistons, as in width & depth. You can all probably guess what im getting at, putting a set of forge gte pistons in my ge once ive finished the turbo conversion. Cheers all Link to comment Share on other sites More sharing options...
dude Posted February 11, 2011 Share Posted February 11, 2011 The same dude, they will drop right in. Link to comment Share on other sites More sharing options...
Nic Posted February 11, 2011 Share Posted February 11, 2011 2JZ-GTE pistons will fit a 2JZ-GE engine. The pistons are Ø86mm x 86mm stroke on both engines. The GTE pistons will lower the compression on a GE motor, although not sure what the squish area will be like using them with the GE head. Link to comment Share on other sites More sharing options...
Guest joey Posted February 12, 2011 Share Posted February 12, 2011 cheers guys, i take it that the cranks and rods are the same aswel? Link to comment Share on other sites More sharing options...
Nic Posted February 12, 2011 Share Posted February 12, 2011 cheers guys, i take it that the cranks and rods are the same aswel? Dimension wise they are the same. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 12, 2011 Share Posted February 12, 2011 The crank and rods are more than just dimensionally the same, they are exactly the same, same part numbers. If you are buying new pistons it would be madness to put them in old bores,, rebore it first over size, which is 86.5 mm or 87 mm depending on piston make and availability. I like Wiseco for a good piston on a budget. Link to comment Share on other sites More sharing options...
Guest joey Posted February 13, 2011 Share Posted February 13, 2011 i was thinking about an oversize bore as most of the pistons im finding are 86.5mm (wossner) Link to comment Share on other sites More sharing options...
