hodge Posted February 2, 2011 Share Posted February 2, 2011 Has anyone got a step by step guide to removing the rear quarter windows. When my car is being painted I'm taking a week off work to do all the prep work at the bodyshop, like stripping the car and flattening back the primer etc etc. Thanks John Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted February 2, 2011 Share Posted February 2, 2011 i will get the info for you mate Link to comment Share on other sites More sharing options...
RobUK Posted February 2, 2011 Share Posted February 2, 2011 Carefully..... I used a Stanley knife to cut through the bond and then gently prized the window away from the body of the car.... Make sure you remove the nuts that hold the window to the body before you start... Other than that it's time and the gentle touch..... It probably took me 30mins at least per window Link to comment Share on other sites More sharing options...
hodge Posted February 2, 2011 Author Share Posted February 2, 2011 i will get the info for you mate Thanks mate I'd appreciate that. Carefully..... I used a Stanley knife to cut through the bond and then gently prized the window away from the body of the car.... Make sure you remove the nuts that hold the window to the body before you start... Other than that it's time and the gentle touch..... It probably took me 30mins at least per window So I first remove the interior panels and that will expose the screws. After that is it just a case of removing the sealant?? Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted February 2, 2011 Share Posted February 2, 2011 Carefully..... I used a Stanley knife to cut through the bond and then gently prized the window away from the body of the car.... Make sure you remove the nuts that hold the window to the body before you start... Other than that it's time and the gentle touch..... It probably took me 30mins at least per window i think that is correct as i know there is 3 nuts on it.. Link to comment Share on other sites More sharing options...
RobUK Posted February 2, 2011 Share Posted February 2, 2011 That's right hodge.... Once removed run the knife around the interior side and then start from the door pillar and work towards the back of the car..... But take your time.... Do not rush it... It's really easy to shatter the quarters... Link to comment Share on other sites More sharing options...
RobUK Posted February 2, 2011 Share Posted February 2, 2011 Ps... Start with the passenger side...... I have a spare Link to comment Share on other sites More sharing options...
hodge Posted February 2, 2011 Author Share Posted February 2, 2011 That's right hodge.... Once removed run the knife around the interior side and then start from the door pillar and work towards the back of the car..... But take your time.... Do not rush it... It's really easy to shatter the quarters... That's brill. Thanks Rob mate. Link to comment Share on other sites More sharing options...
JohnHandy Posted February 2, 2011 Share Posted February 2, 2011 If u have the mr t service manuals x6 that were being sold on here a while back there is a picture showing where the sealant is it's important as some is double row and thicker than a single line I'll see if I can get a pic of the page for you bud. Link to comment Share on other sites More sharing options...
hodge Posted February 2, 2011 Author Share Posted February 2, 2011 If u have the mr t service manuals x6 that were being sold on here a while back there is a picture showing where the sealant is it's important as some is double row and thicker than a single line I'll see if I can get a pic of the page for you bud. Brill cheers John Link to comment Share on other sites More sharing options...
JohnHandy Posted February 2, 2011 Share Posted February 2, 2011 http://184.72.239.143/mu/56994059-b7e4-db4b.jpg http://184.72.239.143/mu/56994059-b79f-3883.jpg http://184.72.239.143/mu/56994059-b7b8-7e50.jpg Link to comment Share on other sites More sharing options...
Stephen G Posted February 2, 2011 Share Posted February 2, 2011 a stanley knife might not do it, it didnt on my car, what you realy need is a knife like this so you put the blade out maybe a couple of inches, i was lucky enough to get a lend of one. http://cgi.ebay.com/ebaymotors/K-Tool-70545-18-Inch-Professional-Windshield-Knife-_W0QQcmdZViewItemQQhashZitem20b3aa5138QQitemZ140453237048QQptZMotorsQ5fAutomotiveQ5fTools Link to comment Share on other sites More sharing options...
Stephen G Posted February 2, 2011 Share Posted February 2, 2011 it is very easy to cut the trim around the window when using the wire to cut the sealent Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 2, 2011 Share Posted February 2, 2011 (edited) The easiest way is to pay a pro using a Fein power tool to cut them out. I have done loads of Skyline ones and have decided if I had bought the right tool initially I'd have saved many hours and two broken windows and some damaged trim. http://www.rejel.com/category/80.aspx A how to using a Fein tool on a Ford Scorpio front screen http://www.fordscorpio.co.uk/manual/windows/windscreen.pdf Edited February 2, 2011 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
