Smoke_U Posted January 9, 2011 Share Posted January 9, 2011 I´m about to buy euro cams for my Auto TT J-spec. Q: Do cams need to be fine tuned once installed or is it just to slap them on and of i go!? Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 10, 2011 Share Posted January 10, 2011 Ideally they want setting up with vernier adjustable pulleys, but lining up the dots will work. I'd be more concerned how you will be adjusting timing and mixture to take full advantage of the different breathing characteristics of the new cams though. Link to comment Share on other sites More sharing options...
Nic Posted January 10, 2011 Share Posted January 10, 2011 The exhaust cams are the same on the Euro/UK Spec and J-spec Supras. The Euro/UK Spec intake cam is longer duration and higher lift compared to the J-spec. Do you have an aftermarket ECU fitted that will be mapped to suit the new cam setup? For the money and effort you'll probably not notice much difference. Link to comment Share on other sites More sharing options...
Smoke_U Posted January 10, 2011 Author Share Posted January 10, 2011 Ideally they want setting up with vernier adjustable pulleys, but lining up the dots will work. I'd be more concerned how you will be adjusting timing and mixture to take full advantage of the different breathing characteristics of the new cams though. ok, so i need to get some adjustable pulleys. Duable! Thanks! Link to comment Share on other sites More sharing options...
Smoke_U Posted January 10, 2011 Author Share Posted January 10, 2011 Nic: No i dont have an aftermarket ECU. Sounds expencive.... Im hoping that Chris´s tip is good enugh! In the future i know i can still gain a little extra with an a.m ECU. Thanks for the advice/tip! Link to comment Share on other sites More sharing options...
