ulysees Posted January 15, 2011 Author Share Posted January 15, 2011 Had a look this morning nd found this wire thats the same colour as the burnt one in drivers footwell could this be it as its in the same loom as were the burnt one goes into? how can i test to see if t is? the middle one of the three, green orange with pink spots Link to comment Share on other sites More sharing options...
Konrad Posted January 15, 2011 Share Posted January 15, 2011 I think you are overcomplicating it Take drivers door card out, there is small white connector on the right side of the door with 3 cables going through it. Clean it, give it some water and rust repelant and check again Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 15, 2011 Share Posted January 15, 2011 I'm gutted for you mate, I as hoping of would be a matter of 'call sparky - sparky comes - hand over shed loads of cash - cars fixed. But no. My locks are still playing up as well mate Link to comment Share on other sites More sharing options...
Keefred Posted January 15, 2011 Share Posted January 15, 2011 Is one of the wires that goes into the door lock solenoid in the drivers door the same colour ? Look at the solenoid and see. If it is thats one step further forward as you will know for sure that the wire thats split into 3 in your last picture does actually control the door lock. The only way you are going to know for sure is to actually look at the door motor and see what colour the wire is, something which I am not sure you have done yet ? If it is I would then trace this wire back from the door lock motor all the way to where it plugs into the drivers footwell, just in case where the plug with the melted wire in has different colours coming out of the back of it than goes into it, Id like to think that one of those 3 wires is the same colour from where you are holding it all the way to the door lock but you never know. The fact that its one wire split into 3 would make me also check what colour the one in the passenger door that goes to the solenoid is as well. I am thinking perhaps that the central locking, which as far as I know only works from the drivers door might have an extra wire on the drivers door lock, possibly the same colour as one of the ones that splits into 3, so that when you lock the drivers door with the key a contact is made from that to the control unit to some sort of change over relay which then sends a current or earths it for a second down the other 2 wires to lock the doors. Link to comment Share on other sites More sharing options...
ulysees Posted January 15, 2011 Author Share Posted January 15, 2011 Right i found were the burnt wire stops burning, its just up in the dash about two feet from were it starts at the fuse box, it joins in to one wire along side another(2into1) so im gunna replace the knackered one and try it. I did take door card off again tody and checked all wires and plugs and gave them a squirt of wd40 all seems fine in both doors. Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 16, 2011 Share Posted January 16, 2011 Did you have any luck once you replaced the wire mate? I took my door trims and most of the dash off today and looked at my wires, they look fine. I'm thinking of changing the central locking unit and then if I get no joy using a blowtorch on the car as I'm reaching the end of my patience.... Link to comment Share on other sites More sharing options...
ulysees Posted January 17, 2011 Author Share Posted January 17, 2011 if I get no joy using a blowtorch on the car as I'm reaching the end of my patience.... lol.. No mate i changed the wire and it made no difference to the locking so no sure what that wire does but at leased its replaced now and cant short out on anything. The sparky's coming to me again tomorrow for another go at it, ill keep you posted on the outcome Link to comment Share on other sites More sharing options...
ulysees Posted January 18, 2011 Author Share Posted January 18, 2011 The sparky came today and you wouldnt believe it but its started working on him again within 2 mins of him being there,but it didnt work for me at all so he didnt charge me, ill be back again no doubt he said. it even works with the red box plugged in now:wtf: Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 18, 2011 Share Posted January 18, 2011 Typical, I hope that is the end of it for you mate Link to comment Share on other sites More sharing options...
ulysees Posted January 18, 2011 Author Share Posted January 18, 2011 I doubt it im just waiting for it to go again mate and then we can meet up and do your blow torch idea on both cars and dance around then and watch em burn:bang: Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 18, 2011 Share Posted January 18, 2011 As its so intermittant on yours it makes me think it is a loose or damaged connection. mine is just buggered. hopefully a new central locking unit will sort it, if not i will bring the blowtorch mate! Link to comment Share on other sites More sharing options...
jagman Posted January 18, 2011 Share Posted January 18, 2011 probably the switch inside the lock motor is sticking Link to comment Share on other sites More sharing options...
ulysees Posted January 19, 2011 Author Share Posted January 19, 2011 All is still ok and working today, and still on the old red box. BUT the button on the door panel only locks not unlock hmmmmm maybe theres the problem, in the button? if mine stays ok then you can have the blue box from me if you like and try that in yours Gaz. Link to comment Share on other sites More sharing options...
TJP Posted January 19, 2011 Share Posted January 19, 2011 Not sure if this will help at all but I had the same problem around this time last year. I did a search on here and quite a number of people have your or our problem. From memory mine and a few others central locking starts to play up when the temperature outside drops to around freezing????? ps so you will be fine in the summer :o) Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 19, 2011 Share Posted January 19, 2011 All is still ok and working today, and still on the old red box. BUT the button on the door panel only locks not unlock hmmmmm maybe theres the problem, in the button? if mine stays ok then you can have the blue box from me if you like and try that in yours Gaz. it could be a problem in the button switch relay.... mine is still playing up, i have just paid keron for the box mate, along with a few other bits, thanks for the offer though, i really appreciate that. once the other unit arrives i will be taking both door cards off and all the trim glove boxes etc, hopefully i will stumble across the problem, otherwise its the sparky for me! Link to comment Share on other sites More sharing options...
