Parry_10 Posted January 3, 2011 Share Posted January 3, 2011 by the looks of my flywheel it needs resurfacing, been reading up the supra flywheels cant be skimmed but im sure this one is just a solid flywheel not a dual mass... Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 3, 2011 Share Posted January 3, 2011 yea the dual mass flys cant be skimmed. these are fine, i have had mine skimmed with no issues, make sure you use a good engineer that can remove the locating studs and correctly replace then, and they must take the exact same amount from both faces . ie the contact face and wher the pressure plate bolts on. Link to comment Share on other sites More sharing options...
Parry_10 Posted January 3, 2011 Author Share Posted January 3, 2011 ok so where the contact face is thicker than the face where the pressure plate bolts on this needs to stay the same? and cant all be skimmed flat? Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 3, 2011 Share Posted January 3, 2011 no , it has to be the same as it goes towards how much pressure is clamped againsed the friction plate. Link to comment Share on other sites More sharing options...
