imi Posted June 14, 2005 Share Posted June 14, 2005 HI all. OK this is what I have done. Ive pulled the fuse (7.5A) out This resulted in the OD light flashing. I then removed the bulb from the dash. question is, is my TRACTION CONTROL DISABLED, reason I ask is that I DID NOT press the trac control OFF switch. common sense tells me that it is off, but i am being paranoid and want confirmation. Regards Link to comment Share on other sites More sharing options...
paul mac Posted June 14, 2005 Share Posted June 14, 2005 do you have an auto or a manual ? Link to comment Share on other sites More sharing options...
imi Posted June 14, 2005 Author Share Posted June 14, 2005 manual... Link to comment Share on other sites More sharing options...
heckler Posted June 14, 2005 Share Posted June 14, 2005 easiest way... disconnect the trac ecu - the one next to the engine ecu Link to comment Share on other sites More sharing options...
imi Posted June 14, 2005 Author Share Posted June 14, 2005 easiest way... disconnect the trac ecu - the one next to the engine ecu so there is no need to switch off the TRAC control BEFORE disconnecting the Trac ECU? Link to comment Share on other sites More sharing options...
adi2009 Posted June 15, 2005 Share Posted June 15, 2005 so there is no need to switch off the TRAC control BEFORE disconnecting the Trac ECU? I really dont think that would matter. Link to comment Share on other sites More sharing options...
heckler Posted June 15, 2005 Share Posted June 15, 2005 so there is no need to switch off the TRAC control BEFORE disconnecting the Trac ECU? nope - i didnt. i now use the trac ecu as a door stop... Link to comment Share on other sites More sharing options...
Duffers Posted June 15, 2005 Share Posted June 15, 2005 nope - i didnt. i now use the trac ecu as a door stop... Link to comment Share on other sites More sharing options...
