stevie_b Posted June 24, 2005 Share Posted June 24, 2005 It senses direct sunlight on the windscreen and uses it to adjust the air conditioning - and it works too. I went into a tunnel in France and the aircon fan dropped two speeds almost immediately, and responded again on exiting the tunnel, cranking the fan speed back up again. Where's my prize -Ian Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 24, 2005 Share Posted June 24, 2005 It senses direct sunlight on the windscreen and uses it to adjust the air conditioning - and it works too. I went into a tunnel in France and the aircon fan dropped two speeds almost immediately, and responded again on exiting the tunnel, cranking the fan speed back up again. Where's my prize -Ian Correct so far, it also does something else too... No prize yet... Link to comment Share on other sites More sharing options...
Fifty Posted June 24, 2005 Share Posted June 24, 2005 If light is low does it turn the doorlock lite on? 50 Link to comment Share on other sites More sharing options...
Rob Posted June 24, 2005 Share Posted June 24, 2005 As it's black, does it absorb just UV light? It would be nice if it would brighten the dash and radio lights in bright sunshine. Link to comment Share on other sites More sharing options...
Lazarus Posted June 24, 2005 Share Posted June 24, 2005 Should point out that not everyone will have the tweeter behind that grill - only UK and J spec GZ models. Everyone else should only have the four speaker system fitted as standard. Actually ALL Supra's have the tweeters. The only difference with the audio is on JDM GZ models which have a bigger amp and a sub in the boot. Not even the almighty UK spec got that! Just to be awkward on this one lads, I have the top spec 7 speaker system in my SZ, well I did have until I started modding the sound system. I think you'll find it was an option on any of the JDM models. Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 24, 2005 Share Posted June 24, 2005 Just to be awkward on this one lads, I have the top spec 7 speaker system in my SZ, well I did have until I started modding the sound system. I think you'll find it was an option on any of the JDM models. Yes, you are correct. Standard on all GZ's, but an option for all other models. Link to comment Share on other sites More sharing options...
Rob Posted June 24, 2005 Share Posted June 24, 2005 As for the dome, blob, solar sensor... Anyone know exactly what it does? Prize for the first one to get it right Does it control whether hot or cold air gets blown onto the windshield, in cold temps, depending on whether the car is in sunshine or not. There is a temp sensor in the dash which I presume is the main control for the Climate Control settings. Link to comment Share on other sites More sharing options...
Matt T Posted June 24, 2005 Share Posted June 24, 2005 Correct so far, it also does something else too... No prize yet... Does it adjust the dash/console illumination? Link to comment Share on other sites More sharing options...
