Loss of power at high revs...?!?!
hogmaw
Going down the motorway in 5th gear at 70 in the Astra and all of a sudden the power cuts out, but the engine still runs. Can't accelerate much, but can trundle along at 60 no probs. If I put the car into 4th the revs go high but pressing the accelerator doesn't do anything at all. Basically, at high revs in any gear (3 or 4k on this car) the accelerator pedal doesn't seem to work! Any ideas?
Just incase you aren't very mechanically minded, have you checked the oil level recently?
How is the coolant temperature when the rev's top out?
Sounds to me like overheating from not enough coolant (leaking rad?) or critical oil level and semi-seizure. Only things I can think of from experience that produce the same symptoms.
The power loss could be from detonation and timing retard to protect the engine. If it gets too hot, it will ignite the air/fuel charge before TDC or whatever advance is set and it will try to run backwards, (causing major damage if severe enough), so the engine waits until later to fire the spark plug/s and you lose the 'sweet spot' and then some!
Could be a failing fuel pump or blocked injector/s, air/filter. Could be many things. Try to find someone to ride with you who has a 'sixth sense' about engines, like a mechanic.
What won't do any harm and might help is a bottle of Wynn's or Lucas injector cleaner in a low fuel tank, so it's quite concentrated. Will give a noticeable improvement in power if the injectors are dirty and a much cleaner exhaust.
Edited by Morpheus
additional thoughts (see edit history)
hey is it a red one...OOooooh if it is your in trouble, blue ones can run funny too.
Mate please give us a clue of what spec your exactly driving and you never know you might even get an answer instead of a guess!
On a brighter note....i've always liked the look of your supra ....very tastfull:-)
