Hoppy Posted September 25, 2010 Share Posted September 25, 2010 I'm having a clear out. All prices + p+p Pair Of OEM Rear Speaker Covers - £5 Stock BOV - £10 AN Fittings + Stainless Hose (Brand New) AN10 bulkhead nut - £2 AN8 bulkhead nut - £2 AN6 male T-piece adapter - £3 AN6 alum weld on adapter - £2 AN4 -AN4 straight adapter (male-male) - £2 Large RED hose finisher (suit 35-40mm hose) - £4 AN12 Red Hose Separator - £3 1.1 Metre length x 22mm id red silicone hose (3 ply) - £7 74cm length x 22mm id red silicone hose (3 ply) - £5 Used AN Hoses + Fittings 1 metre x New AN4 Stainless Braided Hose + used 90 degree fitting - £10 (Would make a nice single turbo oil feed line. Would require straight fitting on other end) 4 x HKS M18 - AN10 Adapters - £2 each (steel) Also got a J-spec pre facelift TT M/T OEM trac ecu £20 Thanks Link to comment Share on other sites More sharing options...
mwilkinson Posted September 25, 2010 Share Posted September 25, 2010 Interested in the AN10 fittings. I appreciate they are used but can you just confirm that they are all in good working order. That is they come apart as they should and there are no damaged threads? Also I assume they were from an oil cooler setup, and as such they have only had engine oil through them? Link to comment Share on other sites More sharing options...
Hoppy Posted September 25, 2010 Author Share Posted September 25, 2010 First post updated. All the used AN10 fittings are now sold sorry mate. Link to comment Share on other sites More sharing options...
mwilkinson Posted September 25, 2010 Share Posted September 25, 2010 First post updated. All the AN10 fittings are now sold sorry mate. Poo Link to comment Share on other sites More sharing options...
Hoppy Posted September 26, 2010 Author Share Posted September 26, 2010 Link to comment Share on other sites More sharing options...
monsween Posted September 28, 2010 Share Posted September 28, 2010 Will that red hose connect tight enough over the BOV? Can you check for me Link to comment Share on other sites More sharing options...
Hoppy Posted September 30, 2010 Author Share Posted September 30, 2010 Will that red hose connect tight enough over the BOV? Can you check for me Yes mate, the bov OD is 20mm. The hose ID is slightly larger , but i have checked it, and it tightens up nice and tight. Cheers Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 30, 2010 Share Posted September 30, 2010 that large red hose finisher be any good on a na top hose?? Link to comment Share on other sites More sharing options...
Hoppy Posted September 30, 2010 Author Share Posted September 30, 2010 that large red hose finisher be any good on a na top hose?? Not sure to be honest mate. The exact ID size is 40.42mm, if this helps? Link to comment Share on other sites More sharing options...
Hoppy Posted October 1, 2010 Author Share Posted October 1, 2010 First post updated. Any more 4 Any more? Link to comment Share on other sites More sharing options...
Hoppy Posted October 7, 2010 Author Share Posted October 7, 2010 Link to comment Share on other sites More sharing options...
Hoppy Posted October 12, 2010 Author Share Posted October 12, 2010 Bumpty dumpty! Link to comment Share on other sites More sharing options...
Hoppy Posted October 22, 2010 Author Share Posted October 22, 2010 Link to comment Share on other sites More sharing options...
Hoppy Posted October 26, 2010 Author Share Posted October 26, 2010 £50 delivered for the lot, anyone? Link to comment Share on other sites More sharing options...
