manual and auto,,, engine
pauld36
Just to add to the post above.. If you buy an engine with an auto loom you can use it with both the auto and manual transmissions. However if you buy an engine with the manual loom it cannot be used with an auto tranmission (it is possible to modify though, but would be a PITA). The manual TT also comes with an additional damper on the aux belt.
Also, the flywheel/TC difference goes without saying... :D
