Standing Quarter time translation to power :s
neo1
I know this is a huge area of GREY because all car tuning is very unique... and all our Supras are set up in different ways..... However, at a rough guess what BHP would a supra MK 4 be if it can run a 10.68 standing Qurater. It hasn't been on a RR yet. :shrug:
Quarter mile times depend largely on tyres, suspension set-up, launch method, amount of grip, etc. As colsoop says, terminal speed is a much better indicator of power. For a 10.68 I imagine you'd be talking roughly 600HP+ at the crank at the very least.
:looney:
127 mph, Dunlop S 9000's, Not heated up and not on launch pad glue.... Getting relative spin up in first and some in second as the suspension needs the compression / rebound fine tuning. Ran 4 passes, this was the best time. Worst i did was a 12.3 but that was spinning up in third gear as im still a little trigger happy :eyebrows:
Er, surely these power outputs are a little high...? Terry got a terminal speed of about 125mph at the brunters bash and he's got around 550bhp... I would have though 800 would get you up in the high 140mph mark?
-Ian
Simple formulas for ET and Speed HP calculation
The formula is: hp = weight / (ET / 5.825)3
The formula is: hp = weight * (speed / 234)3
Using the ET method for 10.68 sec, I come up with 600 horsepower
Using the Speed method for 127 mph, I come up with 592 horsepower
I have a lightweight bonnet and cone, so not a huge weight loss really. I think 800 way off the radar....(i wish) I was told a possible 600, i think in reality myself it's more like a solid 550 on high boost, does this make any sense to anyone :drown: However, the tuning is a COMPLETE Enigma, it still uses sequential turbos which is very odd given the times it is running.
I knew you would laugh, a couple of people that i know did as well :cry:
It just doesnt make sense.... I drive it and i don't see how its possible. The only way i think it could be doing this is if engine itself has had mucho internal work done. I was told the turbos have had staged internal re-work and ceramics replaced but still :tumble: Its all talk and guess work that friends in the know have given me, i dare not take it apart as it works and works well. Photos are pointless, it just looks normal other than the HKS FMIC induction and injectors, no bling anywhere to be seen, and stock manifolds and throttle body. Hmm, dont want to be drilled into the ground by everyone because its not a single conversion so will book it onto a RR and post what it comes up with. :giveup:
We aren't laughing but I'm sure some people will find it hard to believe.
They best time anyone here has run on stock tubbies is 11.9 - that was an auto with an uprated stall and a good drag racing driver. With a proper strip, tyres, line lock, burnout etc you could get low 11, maybe even a ten (they can in the states) it just sounds hard to believe. Then again it might not be stock turbo's at all.
Have you got the slip? Which track was it at?
Gaz.
No ones slagging you. 10.6 is unbelievable on stock turbos as it usually takes cars on Drag radials and pushing ~ 800-900 bhp to achieve those times, usually with huge single turbos.
So either there has been a mistake somewhere like with the timing or you have had massive engine upgrades. 12.1 is much more realistic. 10.6 is world record breaking.
Ok i am going with a time mistake here, it just does not seem possible at all. But it did repeatedly run high 11's. I am taking it to pod in a couple of weeks and im sure there times are spot on. The reason i posted this is because i couldnt make any sense of the time in the first place, i know you need a big single and all the rest to get even close to that sort of time. Either that or a twin single HKS type setup. A muck up must have been made.
Maybe you have hybrids? They look the same but you could be pushing out 500~ bhp. Do you have a FMIC etc?
You'd certainly know if you had HKS twins, as they'd be slapped over the 2 big shiney turbos :D
looks like this pig fly's faster lol
I seriously doubt it :)
