Steve Posted May 30, 2010 Share Posted May 30, 2010 I need a replacement Water temperature sensor for the Air con unit. It is located above the ECU area in the heater/aircon unit. Thanks Link to comment Share on other sites More sharing options...
Wez Posted May 30, 2010 Share Posted May 30, 2010 Sadly I took the whole lot down the skip Link to comment Share on other sites More sharing options...
Kirk Posted May 30, 2010 Share Posted May 30, 2010 Is that the thermistor your after as its the only thing i can find on the epc that looks similiar? Link to comment Share on other sites More sharing options...
Steve Posted May 30, 2010 Author Share Posted May 30, 2010 Sadly I took the whole lot down the skip Is that the thermistor your after as its the only thing i can find on the epc that looks similiar? Yeah, it is accessible from just above the ECU. You pull out a metal clip then this pulls out. It has a plug further down the wire. This one has gone open circuit so the air con doesnt work. I did temporarily fit a resistor to the loom where this plugs in just to prove it, with the resistor fitted the fault clears. Link to comment Share on other sites More sharing options...
Kirk Posted May 30, 2010 Share Posted May 30, 2010 There's two listed. Dont know if its any help but the part numbers are 88652-14120 88790-14130 Link to comment Share on other sites More sharing options...
Steve Posted May 30, 2010 Author Share Posted May 30, 2010 Thanks mate, will pop down to Toyota on tuesday and see what they say. Link to comment Share on other sites More sharing options...
