mitsi_matt Posted April 16, 2010 Share Posted April 16, 2010 right i have a 1jz soarer tt with a r154 twinplate orc & a tt supra auto. im going to break the soarer in favor of the supra & would like to convert the supra to manual using parts from the soarer my question is 1: will the 1jz orc twinplate mate up to the 2jz 2: are 1jz & 2jz bellhousings the same 3: do i need any other parts prop etc Link to comment Share on other sites More sharing options...
garethr Posted April 16, 2010 Share Posted April 16, 2010 right i have a 1jz soarer tt with a r154 twinplate orc & a tt supra auto. im going to break the soarer in favor of the supra & would like to convert the supra to manual using parts from the soarer my question is 1: will the 1jz orc twinplate mate up to the 2jz 2: are 1jz & 2jz bellhousings the same 3: do i need any other parts prop etc 1) Yes. You'll need to use the 1JZ flywheel anyway. 2) If you mean will the 1JZ bellhousing fit the 2JZ crankcase, the answer is yes. 3) I believe you will. If it's a complete, running, manual Soarer, you'd probably be better off selling it and buying a 6-speed conversion. Link to comment Share on other sites More sharing options...
j_jza80 Posted April 16, 2010 Share Posted April 16, 2010 Or dropping the 2JZ and fitting the 1JZ and the R154 Link to comment Share on other sites More sharing options...
Guest ugp Posted April 16, 2010 Share Posted April 16, 2010 or sell me the manual box for my v8 conversion? Link to comment Share on other sites More sharing options...
Swampy442 Posted April 16, 2010 Share Posted April 16, 2010 Just keep the Soarer complete, its worth alot more. You could even sell it and get a 6 speed with change. Link to comment Share on other sites More sharing options...
mitsi_matt Posted April 16, 2010 Author Share Posted April 16, 2010 the soarer is worth more in parts fairy smashued due to drifting & very nato green! almost half what i would get for it would go on a new orc clutch!!!!! thats without all the messing trying to sorce the bits for the box conversion. im happy with the r154 tbh 6speed would be overkill for my requirements. dont want to 1jz it as my 2j is in alot better condition only having covered 51k & the soarer was imported from japan having been used as a drift car there for god only knows how long, since then has been subjected to my bad servicing intervals & given deth. to clarify will the 1jz flywheel fit the 2jz engine? Link to comment Share on other sites More sharing options...
mitsi_matt Posted April 16, 2010 Author Share Posted April 16, 2010 oh and prop's i have obviously the auto prop from the supra & manual prop from the soarer. will either fit or combination of both? Link to comment Share on other sites More sharing options...
