fitting cams
suprab
mate not sure think you need big power ie single before you really benefit from cams, when i changed the belts i used hks pulleys and a hks timing belt, gates aux belt cause toyota list 2 belts for the supra. think the water pump should be ok unless maybe high mileage.
You feel an increase in mid to high end power running longer duration/higher lift cams with stock turbos. Even more with ECU mapped to suit.
I'm not as familiar with UK spec Supras. However only the intake cam is slightly longer duration on the UK spec, the exhaust cams are the same as the J-spec, so it should make a noticeable difference. In256/ex264 cams are a popular set up at BPU levels.
