Anotone Used these arms??
steely
they look ok, but they are from the states. they are alot cheaper. but must involve alot of setting up etc.
i'm getting some second hand ones for the MOT. but was thinking about replacing the lot with these after market items for when i do the underneath restoration.
if i decided to try them. i'll let you know how i get on with them. but wouldn't mind finding out if peeps on here had tryed them first.
They look reasonably well thought out, but will probably have cheap bearings in them that will wear very quickly, but you could probably replace them with good ones at a later date. You realise they will make the car very harsh and noisy, and the joints will need replacing on a regular basis if you use it on the road much??
no i didn't think about that:taped:
