Facelift front lights, no dipped lights?
Lude
not sure exactly what model lights or bumper i have,
heres a pic...
when i turn the lights on 1 click, nothing happens.
when i turn them on 2 clicks, thats main/driving.
then when you push the stoke you have full beam/flash/the strongest 1
there are 3 seperate bulbs within the actual light cluster, the smallest 1 on the outside doesnt light up ever?
Edited by Lude (see edit history)
ah rite i see, thanks for that.
so what bumper is it then?
will the face lift indicators/sidelights fit & look ok with the bumper?
Yours is the stock bumper with the lower lip painted.
Yes the facelift indicators/sidelights will fit your bumper, you will need to drill holes to mount them as the bolts are a different spacing to the pre-facelift indicators. You will also need to splice in the wiring for the sidelights, there is a guide to this HERE
thanks a lot guys.
i was thinking of changing them for clear ones anyway for a more fresher look.
its obviously going to be an issue MOT time without anyway, so will be getting them soon.
would these be ok?
http://cgi.ebay.co.uk/CLEAR-Front-Indicator-Lights-fits-TOYOTA-CELICA-SUPRA_W0QQitemZ370350562513QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item563a9d1cd1
or these?
http://cgi.ebay.co.uk/CLEAR-FRONT-INDICATOR-LIGHTS-TOYOTA-SUPRA-JZA80_W0QQitemZ130373195780QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item1e5ad91804
Fog lights, you will find a rotating part on your headlight stalk.
You could save yourself the hassle and just get your facelifts angel eyed like mine :p
Of course you would only be causing yourself more hassle :D
ok so im about to get these ones...
but the seller has e-mailed me saying
The ones we have are only for the 1997 to 1998 models. Whilst these are the same shape as the 94-97 models they use different brackets and bulb holders which we can't supply and although they could probably be modified I couldn't say so with certainty.
and
Ok - if you are sure you can do this. The rewiring should be fairly straightforward but how do you modify the bracket ?
is this the correct one to get?
conversion kit?
can someone post a link to which ones just go straight on?
(know you have to dril hole in bumper or remove 1 of the stolk things on them)
None go straight on mate, not if you go from orange indicators to facelift style.
The Ebay ones don't include the bulb holders and wiring, you will need to buy these separately from Toyota.
As I posted previously, you will need to buy the wiring harness/bulb holders separately as they are not included with the Ebay ones.
The Toyota part number for the harness/bulb holder is 81515-14390, you will need to buy 2 of these.
You will need to splice in the wiring for the side lights, there is a how to guide HERE
yea i know you have to buy the wires etc & splice,
its just the way the seller said the brackets were different it threw me off.
thanks guys will order the lights now. :D
do you know how much toyota charge for the bulb older/wires roughly?
I mentioned that earlier too :p
