p3te Posted February 22, 2010 Share Posted February 22, 2010 Has anyone got a standard air box fitted with a front mount intercooler? I’d like to change the intake on mine (it’s currently got a green hks mushroom) and was just wondering if it would fit? Or would I have to go for another aftermarket intake like the apexi? Link to comment Share on other sites More sharing options...
Scott Posted February 22, 2010 Share Posted February 22, 2010 I don't have a stock one but I have an ARC filter. It is a PITA to install with the hardpipe kit. It all depends on what way your hardpipe kit goes basically. Best bet would be to borrow one for a trial fit Link to comment Share on other sites More sharing options...
p3te Posted February 22, 2010 Author Share Posted February 22, 2010 I don't have a stock one but I have an ARC filter. It is a PITA to install with the hardpipe kit. It all depends on what way your hardpipe kit goes basically. Best bet would be to borrow one for a trial fit i think your right there i might have to get hold of one and try and see if it fits, even the hks mushroom filter looks very close to the pipe Link to comment Share on other sites More sharing options...
mwilkinson Posted February 22, 2010 Share Posted February 22, 2010 (edited) I have a Greddy M-Spec FMIC with a stock air box installed. It was a PITA to make fit and is very tight. Personally I found the stock air box much better for power delivery over my HKS induction kit I had previously. I would say it definitely improved the responsiveness. Edited February 22, 2010 by mwilkinson (see edit history) Link to comment Share on other sites More sharing options...
p3te Posted February 22, 2010 Author Share Posted February 22, 2010 (edited) I have a Greddy M-Spec FMIC with a stock air box installed. It was a PITA to make fit and is very tight. Personally I found the stock air box much better for power delivery over my HKS induction kit I had previously. I would say it definitely improved the responsiveness. how did you end up fitting it? did you just have to cut a bit of it away? i have a trust/greddy fmic also have you any pics of the fit? Edited February 22, 2010 by p3te (see edit history) Link to comment Share on other sites More sharing options...
Supra2jze Posted September 20, 2016 Share Posted September 20, 2016 BUMP Need help relocating the pipe that meets the standard Airbox. Has anyone got any pics? Thanks Link to comment Share on other sites More sharing options...
mwilkinson Posted September 20, 2016 Share Posted September 20, 2016 I ended up having to heat up the stock airbox where the pipe crosses it and then distorting the plastic slightly to give me enough room to make the pipe fit. Not ideal and I wouldn't recommend to anyone. Link to comment Share on other sites More sharing options...
