RobD Posted January 31, 2010 Share Posted January 31, 2010 On my VIN plate my diff is apparently a LSD (A01B). But after having my car on the ramp and spinning the wheels, my wheels spin the opposite way! Surely if its an LSD the would spin the same way!? Spoke to Dave on saturday ( Supraloopy) and he was saying that he had a members car that had supposedly a LSD diff fitted to it and that he done the same as me ( span the wheels) to find they rotated the opposite way, he said he weren't to sure but thinks they maybe LSD diffs just spin the opposite way some how! He also said to check just burn the rears up and see if you have two tyre marks instead of one! (Blokes a legend!) But i've tried and it doesn't leave tyre marks the way i do it and i'm not that confident to hang on the brakes at the same time so it does a standing burnout! Has anyone else ever come accross this? I need to sort this out as i've changed the oil in the diff and not thinking its an LSD diff i've put non LSD oil in her! Obviously i don't want my diff going wrong so i need to know if it is/isnt an LSD diff! Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 31, 2010 Share Posted January 31, 2010 foot to the floor, of the clutch n on the brake have a go its fun Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 31, 2010 Share Posted January 31, 2010 take the back plate off rob and take a look Quote Link to comment Share on other sites More sharing options...
dude Posted January 31, 2010 Share Posted January 31, 2010 No Supra has an LSD!!!!! S you dont need to worry about the oil, ordinary 75/90 will be fine and spinning the wheels with the car in the air won't tell you anything either, you need to try and see if it leaves 2 black lines.......must try harder!! Quote Link to comment Share on other sites More sharing options...
RobD Posted January 31, 2010 Author Share Posted January 31, 2010 take the back plate off rob and take a look I was going down that route next but atm i'm stacked out at work and wont have time til the end of february at least, want to get it sorted asap! Quote Link to comment Share on other sites More sharing options...
miko_supra Posted January 31, 2010 Share Posted January 31, 2010 The diffs need to be under load to be affective am I right? Quote Link to comment Share on other sites More sharing options...
RobD Posted January 31, 2010 Author Share Posted January 31, 2010 No Supra has an LSD!!!!! S you dont need to worry about the oil, ordinary 75/90 will be fine and spinning the wheels with the car in the air won't tell you anything either, you need to try and see if it leaves 2 black lines.......must try harder!! Thanks! Quote Link to comment Share on other sites More sharing options...
dude Posted January 31, 2010 Share Posted January 31, 2010 take the back plate off rob and take a look They all look very similar unless you know What you are looking for. Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 31, 2010 Share Posted January 31, 2010 oh comeon its like 8 bolts and a twat from a hammer and its off! 2 minutes work! as dude said they all use the same oil type so that doesnt realy matter! how did you get to work for toyota again? They all look very similar unless you know What you are looking for. he should know, he works for toyota Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 31, 2010 Share Posted January 31, 2010 i take it these diffs are TorSen as in torque sensing so you cant do the usual of jacking it up, only way to be certain is open it up. FYI i have an NA LSD at work and when you spin one side the other spins the other way. Theres alot of info on TorSen diffs on mx5 websites. Quote Link to comment Share on other sites More sharing options...
dude Posted January 31, 2010 Share Posted January 31, 2010 The diffs need to be under load to be affective am I right? Correctomundo Quote Link to comment Share on other sites More sharing options...
RobD Posted January 31, 2010 Author Share Posted January 31, 2010 oh comeon its like 8 bolts and a twat from a hammer and its off! 2 minutes work! as dude said they all use the same oil type so that doesnt realy matter! how did you get to work for toyota again? he should know, he works for toyota Well i must be doing something right mate, when we was slow on work i still kept my job Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 31, 2010 Share Posted January 31, 2010 Well i must be doing something right mate, when we was slow on work i still kept my job thats cause i work for a knob Quote Link to comment Share on other sites More sharing options...
RobD Posted January 31, 2010 Author Share Posted January 31, 2010 The diffs need to be under load to be affective am I right? Correctomundo I done the same test on a land cruiser and both wheels turned the same way! The foreman at my place seemed to be convinced that it was a non lsd type aswell! I've never really had anything to do with diffs so its a little new to me! Will take the car out tomorrow and give her a good burning! Quote Link to comment Share on other sites More sharing options...
RobD Posted January 31, 2010 Author Share Posted January 31, 2010 thats cause i work for a knob Quote Link to comment Share on other sites More sharing options...
Kirk Posted January 31, 2010 Share Posted January 31, 2010 I've never really had anything to do with diffs so its a little new to me! and i thought you were taking engines to bits and replacing every mechanical part on cars not just changing oil and a few spark plugs Quote Link to comment Share on other sites More sharing options...
RobD Posted January 31, 2010 Author Share Posted January 31, 2010 I know i should work in kwik fit really Quote Link to comment Share on other sites More sharing options...
deathmonkey Posted February 1, 2010 Share Posted February 1, 2010 I know i should work in kwik fit really Quote Link to comment Share on other sites More sharing options...
edinlexusV8 Posted February 1, 2010 Share Posted February 1, 2010 (edited) Wheels spinning in opposite directions when the car is upheld on a ramp, dosnt mean anything. I have an LSD and during installation I did notice the same behavior too. But you can only talk about the spin when the wheels are under load! I am pretty sure that you have an LSD in your car form your axle code! If you need any more information check my thread in here about an LSD installation, you might find some answers http://mkivsupra.net/vbb/showthread.php?t=202553 Cheers Edited February 1, 2010 by edinlexusV8 (see edit history) Quote Link to comment Share on other sites More sharing options...
RobD Posted February 1, 2010 Author Share Posted February 1, 2010 Thanks for that mate! Checked this today and it does definitely have an LSD fitted so i'm alot happier now! Thanks for all the advice and help! Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 1, 2010 Share Posted February 1, 2010 so comeon then genius... how do you tell the difference between the 2 or did you just do the burnout test? Quote Link to comment Share on other sites More sharing options...
RobD Posted February 1, 2010 Author Share Posted February 1, 2010 Jacked up one wheel and see if it would just turn the one wheel or turn both! Then i took it out side and lit the tyres Just to make sure like! Quote Link to comment Share on other sites More sharing options...
Scutch0 Posted February 6, 2010 Share Posted February 6, 2010 Sorry for the thread hijack, but I just wanted to know if there is much you need to change to fit a LSD to a non LSD equipped supra? Will the tt diff fit ok? Quote Link to comment Share on other sites More sharing options...
