trinitom Posted November 28, 2009 Share Posted November 28, 2009 my car is making a strange sound on idle like the one when the turbo is going poff "the famous whine sound". this only happens at 600rpm if more than that the sound disappear. i thing the sound is coming from the top of the head exhaust side. can someone tell me if there's any bearings on the camshaft's or pulleys? thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 When is your engine at 600rpm? Sounds like a different fault to mine, I would have to nearly stall my engine to get it that low. It constant or only after heating up? Cold start etc etc. Quote Link to comment Share on other sites More sharing options...
edge Posted November 28, 2009 Share Posted November 28, 2009 600rpm? not 6000? Can you do a sound recording of it and post up? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 600rpm? not 6000? Can you do a sound recording of it and post up? He says "idle" but 600 seems VERY low to me. Sounds like that could be something to do with it, like the engine trying to suck really hard through the nearly closed throttle. Quote Link to comment Share on other sites More sharing options...
edge Posted November 28, 2009 Share Posted November 28, 2009 He says "idle" but 600 seems VERY low to me. Sounds like that could be something to do with it, like the engine trying to suck really hard through the nearly closed throttle. Yes my bad I don't think the turbo will be spinning or spinning enough to create any pressure unless it was a bearing but that will lead to alot of smoke etc. Maybe a alternator bearing? Hard to judge without hearing it? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 Yes my bad I don't think the turbo will be spinning or spinning enough to create any pressure unless it was a bearing but that will lead to alot of smoke etc. Maybe a alternator bearing? Hard to judge without hearing it? Can't see any way of it being the turbo. The stock turbo's don't spin as freely as you would think. They spin up during idle but not enough to create any real pressure. The engine sucks a lot harder than they blow at idle ooeerr. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 When is your engine at 600rpm? Sounds like a different fault to mine, I would have to nearly stall my engine to get it that low. It constant or only after heating up? Cold start etc etc. well mine normally sits at around 600/50rpm and sounds normal, about the sound it's constant and only after fully warm. 600rpm? not 6000? Can you do a sound recording of it and post up? yes i can do but only tomorrow. Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 well mine normally sits at around 600/50rpm and sounds normal, about the sound it's constant and only after fully warm. yes i can do but only tomorrow. I think the norm is about 800 at idle, 600 is certainly low. When it starts to make the noise gently push on the throttle to get 1000rpm (might be difficult but its a must) and see if the noise goes away. If it does I think it might just be the car struggling to breathe. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 i just replaced the turbos and the sound it's still there, so I’m sure this is no turbo related. looks like the sound is coming from inside the exhaust cam cover. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 (edited) I think the norm is about 800 at idle, 600 is certainly low. When it starts to make the noise gently push on the throttle to get 1000rpm (might be difficult but its a must) and see if the noise goes away. If it does I think it might just be the car struggling to breathe. by just turning the ac on the sound goes away, its just at 600/50rpm, 700rpm and all good edit- how do i turn up the rpm? Edited November 28, 2009 by trinitom (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 Think your idle control needs adjusting. Your engine is struggling to breathe at idle. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 Think your idle control needs adjusting. Your engine is struggling to breathe at idle. if tomorrow doesn't rain, i give it a try. thanks for the help people Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 You are comfortable adjusting your idle control? It's not straight forward to a layman. The reason why it goes away when you turn on the AC is that the engine is having to work harder to run it, hence the revs going up... leading the noise to go away. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 You are comfortable adjusting your idle control? It's not straight forward to a layman. The reason why it goes away when you turn on the AC is that the engine is having to work harder to run it, hence the revs going up... leading the noise to go away. i think i can do it myself with the forum people help if i'm not wrong the adjuster is the one nearly to the throttle cable adjuster right? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 You adjust it using a multimeter and rotating it till you get the correct impedance. Quote Link to comment Share on other sites More sharing options...
Homer Posted November 28, 2009 Share Posted November 28, 2009 For info, a TT should warm idle between 650 and 750 rpm, according to the service manual. Mine always idled at 700rpm, but "felt" like it was a bit low, had it raised to 900rpm with the PFC, felt much better then! Quote Link to comment Share on other sites More sharing options...
RedM Posted November 28, 2009 Share Posted November 28, 2009 For info, a TT should warm idle between 650 and 750 rpm, according to the service manual. I never knew that. Mine always 'felt' a bit low and caused me no end of worry. Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 Maybe the Mines in mine has it raised a little. Mine idles at 800, feels fine Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 For info, a TT should warm idle between 650 and 750 rpm, according to the service manual. Mine always idled at 700rpm, but "felt" like it was a bit low, had it raised to 900rpm with the PFC, felt much better then! what is the PFC? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 28, 2009 Share Posted November 28, 2009 Power FC, stand alone ECU. Quote Link to comment Share on other sites More sharing options...
trinitom Posted November 28, 2009 Author Share Posted November 28, 2009 haa, i don't have that! so the only way to raise the rpm is using a voltmeter and rotating the icv? i'm not very comfortable using voltmeters! Quote Link to comment Share on other sites More sharing options...
edge Posted November 29, 2009 Share Posted November 29, 2009 haa, i don't have that! so the only way to raise the rpm is using a voltmeter and rotating the icv? i'm not very comfortable using voltmeters! Leave that alone then then until you find out if the noise needs attention of whatever is causing it. And as scott said just increase rpm slowly to about 1000rpm to see if it changes/disappears etc Quote Link to comment Share on other sites More sharing options...
