Mondeo - stuttering/hessitation under acceleration
Homer
At low RPM under anything more than 10% throttle the engine stutters, almost like a misfire, but not quite. It's worse at lower rpm, but tends to go away once the revs get above 3500-4000rpm. Once at above that rpm the stuttering goes away and it accelerates as normal.
It seems to be load related as it gets worse the high the gear. Also fuel economy seems to be dropping.
I've changed the plugs even though the originals looked new, but this didn't make any difference. There's no sign of smoke from the exhaust and no other indication of problems other than it not being serviced in a year or two.
Any idea's as to the cause? Air flow meter? Coil packs? Is there any easy way to read error codes? :help: Ford are hopeless, they refuse to do anything until they have hooked it up to their computer, which costs £80. That's without then doing anything else...
It's a 1998 Mondeo 5spd 2.5 V6 (Duratec engine)
That's what I like, two quick replies saying the same thing :thumbs: Thanks guys
I'll go have a look into tps issues, I was getting a bit confused with this before as the Duratec uses a fly-by-wire throttle system, which seems to not be used on the other models. Guess if it's the tps it doesn't matter though?
check all the hoses mate had the same prob with me st200
Had a good look around but there are very few of them and couldn't see any signs of cracks. The engine is very low mileage and everything seems to be in great condition. Any tips as to where to look as the ST200 seems to share then same base engine?
Thanks Steve, very helpful! Will take a look at that tomorrow
When ever these symptoms have come up its been the tps 99.9% of the time. Hope this helps you out mate
Cool, not sure how to check the tps on these engines, but have a feeling a new one is going to cost a pretty penny!
Thanks all for your replies :thumbs:
The way that i check them was by using auto diagnos, basically reading the live data while operating the throttle by hand. By doing this it would show the signal drop out or jump out of range. If you do swap it ideally you will want to set it up watching live data also, to set it up properly.
How should I go about doing that? I don't have an oscilloscope, just a multimeter.
a quick non technical way of doing it is find a donar car with the same set up, then while still in place mark the sensor in a place where you can line it up identical onto your TB. This should be ok for testing, and most of the time is a suitable way of doing it.
  • 1 month later...
Ran out of patience with this so booked it into a local (decent) garage.
Two really simple faults in the end:
1) One of the new plugs I'd bought had a crack in the top insulator
2) One of the clips to the plug (on another cylinder) had a poor connection, it was crimped up as a quick fix
This was resulting in the spark on one cylinder running down the outside of the plug (the plug had a burn line down the outside of the insulator) and was essentially running on 5 cylinders when under load.
Seems to be good now, but still has a occasionally has a little hesitation at low rpm. but nothing at all like before. The garage said the timing report showed some erratic behavour results still, they said the coil packs, TPS and airflow meter were all tested and showed no problem, but though the leads is the most likely cause and recommended replacing those.
Thanks for the advice all :)
