clutch
mikerunner
I have one of my uprated stock clutches for the TT six speed built up ready to go. Price is £475. Info below
Available now: Uprated MKIV six speed Getrag TT clutches.
I use the stock, brand new driven plate, as it is correctly
balanced, doesn't judder and will hold all but mega torque
highly modded engines or cars used for drag racing.
I modify a stock brand new OE cover to give more clamping force.
The reason I tooled up to do these is some of the aftermarket
US clutches I have fitted SEEM to be built from used cover
assemblies with reground friction surfaces, and a stronger
spring. I have had hellish trouble getting these to fully
release, because due to this seemingly thinner cast iron
friction face, the geometry of the clutch goes to pot, and
being a pull type clutch (the hydraulics pull the bearing
away from the engine, rather than the more normal push type)
it is a lot harder to effect a cure.
For 475 pounds, no VAT to pay, you get a brand new driven
plate, a brand new modded cover, and a brand new release
bearing. I would rather fit myself so any complaints are down
to me, I see too many clutches juddering due to someone without
the right gear fitting them, or clutches fitted to patently buggered flywheels.
However, I might be persuaded to sell to people using bona fide fitters to install one.
Toyota use a dual mass flywheel (the flywheel is in 2 parts, an inner and
outer assembly, damped in the middle) which is now showing signs
of wear causing a lot of rattle when idling or on very light
throttle openings. For God knows what reason they are charging
about 270 quid for a new one, they look more like they should be
over 500 to me, but don't say anything :-) So if the flywheels
old enough or abused enough to be scored it's best replaced.
Fitting by myself will cost £175.
Reply privately if interested please. [email protected]
